starvin for fuel
Old Sep 28, 2012 | 11:37 AM
streteglide06's Avatar
streteglide06
2nd Gear
Default starvin for fuel
My 06 street glide run fine up until i do 90 or better. Runs well for about 1 mile, then acts like its running out of gas. Pulled the petcock, clean. only does it at high speed. Thought of installing arlen ness hi flow petcock. Any ideas???
Old Sep 28, 2012 | 11:43 AM
mkguitar's Avatar
mkguitar
check the float level
which main jet ?
which slow jet ?
which needle ?
It is possible that an overly rich high speed is dumping fuel into the motor faster than it can be replenished...and that extra rich mixture ( if so) isn't doing anything for power.
or the float level is set too low
or it may be a petcock issue I don't know the ness, the pingle has been around for ever.
mike
Old Sep 28, 2012 | 01:29 PM
streteglide06
2nd Gear
thanks. will check it out.
Old Sep 28, 2012 | 02:00 PM
mkguitar's Avatar
mkguitar
the CV carb is easy to work on and mod.
nightrider.com has a bike tech section with good notes on the CV carb.
you may also find info on Kawasaki and Triumph focused websites, some of those models used versions of the Keihin CV carb ( CVK)
bluharley
EVO
34
Nov 29, 2012 08:43 PM
harleydwg555
Exhaust System Topics
May 14, 2011 04:18 PM
hdbeggs
Carburetor Related
Feb 2, 2011 08:59 AM
panshovel4life
Shovelhead
14
May 26, 2008 10:25 AM
f6noob
Apr 20, 2007 02:32 AM
