Tire install rear brake thumps
Old Sep 30, 2012 | 08:11 AM
SmittyFXDL's Avatar
SmittyFXDL
Thanks for all the replies. Odd thing is if he rides solo, its hard to replicate the problem. Add a passenger and its easily recreated. Ill ask him to check the caliper and make sure it is seated correctly.
Old Oct 1, 2012 | 07:54 AM
SmittyFXDL's Avatar
SmittyFXDL
Is it normal for a new rotor and brake pads to thump or pulsate when first installed? He's put around 50 or more miles over weekend and the thumping seems to have disappeared now. Wondering if that was normal or a break in period of sorts.
Also, if the brake pads are worn down pretty good can that cause excessive heat to actually warp the rotor?
Old Oct 1, 2012 | 09:24 AM
Pondskipper's Avatar
Pondskipper
The odds are they were fine before, the tech will have pushed the pistons back in when he fitted the tire to make the caliper easier to refit, dirt build up from brake dust on the pistons will have caused the pistons to stick to the seals preventing them from self adjusting until they freed off again, I have seen this a lot in the past, I became a bit of a brake guru over the years. I am doing a complete caliper stip down and rebuild on mine this winter and will be seeking out some ceramic pistons.
Virginian
Jun 1, 2020 10:05 PM
Charlie Fogg
Dec 22, 2012 07:44 PM
mikelikesbikes
Nov 11, 2012 12:32 AM
TRI GLIDER
21
Jul 24, 2009 01:51 PM
beckmanj1
Aug 16, 2008 07:13 AM
