Changing Tires
Old Oct 1, 2012 | 03:03 PM
kdodd's Avatar
kdodd
Default Changing Tires
Any suggestion's on a set of good tire changing tools?
Old Oct 1, 2012 | 09:18 PM
piasspj's Avatar
piasspj
I have the HF tire changer and MC adapter (I don't think they sell it anymore).
I wouldn't use the HF lever on a rim where cosmetics are important.
I added the MOJO Blocks and MOJO lever. It works (better than spoons anyday).
I bent the MOJO lever, I also broke the bolt that hold the plastic end on.
I then bought the No-mar tire changing lever. It works better than the MOJO lever.
Old Oct 1, 2012 | 09:49 PM
2black1s's Avatar
2black1s
I used a bead breaker and set of tire irons that I bought from JC Whitney for years until last year when I bought a used K&L tire machine off of Craigslist.
Are you looking for hand tools or a tire machine?
Old Oct 2, 2012 | 04:39 AM
kdodd's Avatar
kdodd
Hand tools.
Old Oct 2, 2012 | 06:31 AM
robbie52's Avatar
robbie52
Phone with independent on speed dial.
Old Oct 2, 2012 | 08:16 AM
piasspj's Avatar
piasspj
Originally Posted by kdodd
Hand tools.
Not much difference in the different spoons I used. The longer tools will give you more leverage. Plastic from bottles make good rim protectors.
Use plenty of lube, dish soap works OK (diluted with water), tire lube is a little better.
Old Oct 2, 2012 | 08:39 AM
Rickl's Avatar
Rickl
FYI - whatever lube you use make sure it is vegetable based, not petroleum based.
Old Oct 2, 2012 | 10:44 AM
2black1s's Avatar
2black1s
Hand tools.
The tire irons (set of 3) I got from JC Whitney are about 15" long. They always worked fine for me.
big_e78
Wheels/Tires
Sep 4, 2009 06:49 PM
gipsl67
Wheels/Tires
Jul 28, 2009 01:07 PM
rickb
Apr 9, 2008 10:47 AM
doc308
Mar 24, 2008 03:13 PM
principalman
Jul 1, 2007 02:19 PM
