H-D CNC ported heads
Old Oct 3, 2012 | 08:38 PM
Twillis's Avatar
Twillis
My brother-in-law has the CNC Ported Heads on his 103 Fatboy that's good for 123hp/120tq. Can't be too bad on the performance end of things.
Old Oct 3, 2012 | 08:45 PM
cpc0812's Avatar
cpc0812
What else is going on in that motor?
I have them with my 103 build and 255 cams. I also added a V & H pro pipe chrome. Im happy with what I have. I also got a good deal on them.
Old Oct 3, 2012 | 10:17 PM
tazman509's Avatar
tazman509
Surdyke has them right now for $799.96 with a Msrp: $999.95. You could get around $200.00ish for yours as HD does not require a core. They could be covered under your warranty if you go with the HD heads. You can get the work done cheaper on your own heads. You just wouldnt have the "Screamin Eagle" on the heads. That would not be important to me but may be to others. I personally am still debating on which route to go. My bike is still under warranty.
Old Oct 3, 2012 | 10:55 PM
mike_oh's Avatar
mike_oh
Look at DanVanceRacing.com. he does awesome work!!
Old Oct 4, 2012 | 07:28 AM
Neckball's Avatar
Neckball
I'd like to see that dyno sheet.
Old Oct 8, 2012 | 11:31 AM
Mike's Avatar
Mike
These "CNC Ported Factory Heads" also do not have any Screamin' Eagle markings on them. Stock factory head castings are sent over to Wegner for porting, decking, valve work and assembly. They're stealthy.
Old Oct 15, 2012 | 07:28 PM
Juice's Avatar
Juice
local harley shop is running 20% discount in michigan.
Old Oct 19, 2012 | 04:16 PM
hbever's Avatar
hbever
Do they have any provision for compression releases? I am looking at a set for a 95" build. The pic in the 2013 SE catalog shows the auto compression hole. I need the manual compression hole. Just wondering if it is already drilled, like the old se heads were.
Old Oct 19, 2012 | 05:27 PM
cpc0812's Avatar
cpc0812
They are only drilled for ACR, not MCR.
Old Oct 19, 2012 | 07:12 PM
bklynbob's Avatar
bklynbob
Default yep
Originally Posted by FLTR2008TRIKE
I would suggest speaking with a few different engine builders. You can get more bang for your buck with one of them doing your stock heads then what Harley is offering.
http://www.hillsidecycle.com/
http://tmanperformance.com/
http://www.cart.rrcycles.com/
http://www.head-quarters.com/
http://www.atwoodperformance.com/ <<< In Ohio
These are few as a suggestion to speak with to find what your best combination would be for what your trying to gain with your engine
www.larrysmotorcyclemachine.com
