Burning Oil
Old Oct 2, 2012 | 11:05 AM
cochon's Avatar
cochon
Originally Posted by Sharkman73
Both of you that have this issue stated that it hadn't done it until it was serviced. My guess is that the dealer or whoever serviced your bike overfilled the oil in the case, which in turn is going to blow excess back through the breather, which would be more noticeable on decel only since there would be back pressure through the breather during this time rather than a vacuum.
Often times when the crankcase is over-filled, the excess will blow back into the breather, and in extreme cases can even leak out from here.
Check your oil level....where is it on the stick when cold/hot. Many dealers put too much oil in the bike during service...it's common. I believe this could likely be your issue.
I was going to say what he said , only Sharkman beat me to it!
Old Oct 2, 2012 | 11:39 AM
DuraGlide's Avatar
DuraGlide
Don't know about the OP but mine is definitely not overfull. Do all my own service. It's not my imagination either. Have smelled it out in the fresh country air with no one around but me. Happens only when downshifting for a curve, using engine braking to slow down. It's more of a hot oil smell than a burnt smell. The 08 Ultra does have a stage 1 breather, I need to check the rocker box to breather seals to see if that could be the culprit. My 08 SG has twice the miles on it and has never had a smell on decelleration.
Old Jan 8, 2013 | 11:09 PM
Streetdude's Avatar
Streetdude
4th Gear
Default Burning oil smell
Originally Posted by smithbrl
Check the transmission cover on the right side. The 2 bottom screws sometimes get loose and transmission oil can leak down on the header.
Had to take care of this yesterday... only 7800 miles and I recently had the dealer replace my brake light switch under warranty, and they missed it. the bolts holding the bracket were only finger tight, and leaking oil onto my cat. Cleaned it after taking the header off, put back together and went for 30 mile test ride - no more burning oil!
Old Jan 8, 2013 | 11:58 PM
mkguitar's Avatar
mkguitar
FYI the torque value for those bolts was changed to 25 ftlbs.
pain to get at, but I use a 1/4" drive screwdriver bit
insert butt end into the bolt, turn with an open end wrench.
it you do the top bolts first with a torque wrench to about 22 ft lbs, then turn them in with the bit/wrench, you get a "feel" for 25 ft lbs.
mike
Old Jan 9, 2013 | 02:37 AM
stupid_rope's Avatar
stupid_rope
this would be my first thought as well
Old Jan 9, 2013 | 03:40 AM
Stiggy's Avatar
Stiggy
My crankcase is not overfull, the bike still burns no oil and I can smell oil at stops sometimes. I always assumed it was from the breathers. If it aint' broke....
Old Jan 9, 2013 | 07:14 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
I get this smell from the oil vent of my tranny.
I topped the front differential of my truck with the same gear oil I have in the bike. Now I have this "hot engine" smell on the rag I used and you can't miss it
Old Jan 9, 2013 | 09:35 AM
hardheaded's Avatar
hardheaded
this is what i was thinking also,pretty common.
Old Jan 9, 2013 | 11:24 AM
Pondskipper's Avatar
Pondskipper
Is the exhaust popping on overrun?
Old Jan 9, 2013 | 12:10 PM
lionsm13's Avatar
lionsm13
Yep, they do go loose from time to time, but tranny fluid has quite a different smell, and if the service was competent this should have been checked..
Then again, how is one to know this?
Would be a good thing to check..
