10 inch Monkey Bars, need help
Old Oct 15, 2012 | 07:29 AM
mathew2172's Avatar
mathew2172
So the bars and the super size kit showed up this weekend, everything but they sent ot fluids. Kind of surprised by that for the cost. Anyway will be putting these on in a few weeks after i get some odd and ends stuff!
Old Oct 15, 2012 | 07:49 AM
mike1158's Avatar
mike1158
Quick tip: if you put your tires up on a piece of 2x lumber and then set it on its kick stand, causing your bike to lean over little more...you can get the cultch cover off without losing very much fluid at all...
Old Oct 15, 2012 | 09:29 AM
davey019's Avatar
davey019
From what I have been told you can go up to a 10" bar without changing cables and you have to reroute them. I talked with Yaffe on his 10" mini apes and he said you had to change cables because he must measure the height different? From what I understood with him, his 10" acted more like a regular 11" or 12" bar. I have been debating on a lot of bars and am still on the hump, but I am leaning towards the Kromewerks 2+2 sweepers and trying to make them work with just changing the clutch cable. If anyone else has any suggestions please chime in. If you going to go through all the work on changing the bars you might as well paint the inner fairing also. This is my plan
Old Oct 15, 2012 | 03:05 PM
2001Roadking's Avatar
2001Roadking
I just put a pair of Yaffes 10 inch mini apes on an 06 Ultra Glide. Wires were ok, clutch cable needed to be replaced(read to many storys of cable breaking from being maxed out, and brake lines were temporarily mounted with a make shift bracket.(about 2 inches to short even after rerouting). New brake lines on order. I think the Yaffe bars are taller than most others. Probably measured differantly. Love the bars. Installed Friday and a 5 hour ride with the wife Saturday.
To the OP, its a time consuming job but not real difficult.
Old Oct 21, 2012 | 10:41 AM
nachserv's Avatar
nachserv
6th Gear
I recently installed the bars myself on my 09 Roadking. The project was just as everyone on these forums described: a pain but doable.
Old Oct 21, 2012 | 06:43 PM
nachserv's Avatar
nachserv
6th Gear
Here is a pic of the bars on my bike. Best tip I have if internally wiring is to cut most of the black casing that holds the wires and rewrap with shrink wrap to allow them to feed better through the bars, especially the throttle side.
Old Oct 21, 2012 | 07:18 PM
tccraiger's Avatar
tccraiger
thats a good one, would have never have thought of it.
Old Oct 23, 2012 | 08:14 PM
mathew2172's Avatar
mathew2172
Im gonna attempt to put them on this weekend, if anyone is in Omaha Ne and can help with the wireing that would be great!
Old Oct 23, 2012 | 09:27 PM
mike1158's Avatar
mike1158
as an odd coincidence i'll be close, MUCH closer then usual, but not close enough. i'll be driving through Kansas on Thursday...spending the weekend in Denver.. then headed back home starting Monday
I'm delivering a FatBoy to my brother-in-law in Denver, coming from Jersey... ROAD TRIP... i leave in about 7 hours
Old Oct 28, 2012 | 08:44 PM
mathew2172's Avatar
mathew2172
So on the TBW you need to remove the connectors to get them thru the bars, how to do i remove the smaller one? Any help would be great!
