Loose plugs
Old Oct 7, 2012 | 05:42 PM
Florida Swamp Yankee's Avatar
Default Loose plugs
If anybody is having trouble starting when wet check the plugs to see if they have loosened at all. Every time I washed my bike I was having trouble starting when done. Happened after getting soaked when parked during a thunderstorm too. I never had a problem before and was clueless as to why until I was doing a PM and checked the plugs. When I put the wrench to them they were just slightly more than hand tight. I checked the plugs which were fine and have been through thunderstorms and a good wash twice since then with no trouble...
Old Oct 7, 2012 | 06:42 PM
mrfikser's Avatar
mrfikser
thanks, good info. to keep in the old memory bank..
Old Oct 7, 2012 | 07:46 PM
Ride Ultra's Avatar
Ride Ultra
Hmm. Thought it was just me with this issue. Only the rear plug does this. Two times, I could have placed socket on there and probably wrenched it by hand. Front no problem.
Started around the time the freakin engine started shaking like a rabid varmint (another issue). Just snugged them a bit tighter. Haven't noticed any issues as of the past two months.
Old Oct 7, 2012 | 09:33 PM
drukanfu's Avatar
drukanfu
When I put in a new set of plugs, after torquing them to 15 ft. lbs. or 180 inch lbs. I'll loosen it up and re-torque. Seems to "set" the plug washer.
Old Oct 8, 2012 | 01:36 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Same here after applying anti-seize (copper grease), but I use my thumb and index to 'stop before the pain' instead of the torque meter.
Armstronges
Aug 14, 2022 05:04 PM
nevadarider
May 26, 2019 07:18 PM
mrammo
Feb 16, 2012 05:53 PM
donovan51
Nov 14, 2008 06:37 PM
zenwarrior
Jun 28, 2006 06:06 PM
