Rear belt
Old Oct 18, 2012 | 05:31 PM
jossi's Avatar
jossi
6th Gear
Default Rear belt
Hi is there anybody that can help me , how tight should the rear belt be
i have Harleys belt tensioner 4,5kg pressure and how much should the belt
flex
ps. new FLHX owner i think my dealer miss to check the belt tension
Regards
Jossi
Old Oct 18, 2012 | 05:59 PM
mkguitar's Avatar
mkguitar
With my fingers I push up about 4 kgs force. I expect the belt to move 12 to 14 mm
for the FLHX it should be about 8 mm
mike
Old Oct 18, 2012 | 06:33 PM
EasternSP's Avatar
EasternSP
For touring bikes: with bike on jiffy stand, no rider or luggage and 10 psi in rear shocks, apply 10lbs of upward pressure on the belt at mid point and it should flex 1/4 - 5/16".
With rear wheel off the ground, same pressure on belt, it should flex 3/16 - 1/4".
Ya don't want to rely on the method of twisting the belt 90 degrees. Some weak fingered guys can't twist it that far when its laying on the work bench while others can twist it all the way around when its under proper tension.
Old Oct 18, 2012 | 06:50 PM
WI Bob's Avatar
WI Bob
Sometime after a ride on a 90+degree day, check the 1/4" setting. I will be fiddle string taught. I set a click looser nowadays.
Old Oct 18, 2012 | 08:18 PM
lonerider2's Avatar
lonerider2
Default Belt
HD came out with a bulletin a while back for more deflection in belt tension, don't remember for sure but think they now say up to 9/16" deflection, at least on touring models.
Old Oct 18, 2012 | 08:44 PM
Ken Baer's Avatar
Ken Baer
Motion Pro makes a tool called a Tension Gauge (check Amazon.com, they're around $22.00/ea.) made specifically to measure the amount of deflection required. I bought one and have used it on numerous bikes. Works well.
Old Oct 18, 2012 | 08:52 PM
Jackie Paper's Avatar
Jackie Paper
Do the gage. Do not flex, push till it's tight, shake, blow and any variation of all that. If you price the belt, pulleys, inner primary bearing, transmission main gear bearing and labor, that $15-$25 is the only way. A belt change is a big deal of parts laying in floor just to get to it. You also need to read manual since they are different. A Softail changes slightly when loaded, so I lay over seat. The Dynas and Cruisers are checked with nothing on seat I think. Got an extra gage on Amazon. (Needed a loaner) Motion Pro just like Ken said. Must have been a special sale because I only paid about 1/2 of what Harley wants. Exactly like my Harley one.
FXDXTSport
Screamin Eagle CVO Models
Jul 6, 2017 09:28 PM
riderboy1961
Apr 19, 2013 07:48 AM
trackadaptor
Nov 9, 2011 04:07 PM
RockDog
Jun 6, 2010 01:49 PM
dog155
Sep 8, 2008 09:52 AM
