Yeah, my old bike (87 classic) would crank in gear with out the clutch being in, gave my self whiplash a couple times hitting the start button while sitting on it, got in the habit of leaving it in neutral most of the time. Probably a good Idea to use ACC to listen to the radio.
Reason: typo
Same routine all the time. Put it in N, kill switch, ignition switch.
Only exception is if I'm facing a slight downgrade, then I put it in first so it won't roll forward.
I always turn mine off with the on/off switch, then the ignition switch. Just a habit I got into from day one.
+ 1, also I never hit the starter without having the clutch fully depressed. There are times when parking on a slight non level area I will park bike in gear. Having always depressed clutch before hitting starter I've never had to chase my bike all over a parking lot, garage, etc. It just becomes a habit.
Oh yeah now it is hilarious, no doubt wish "this guy" would have had time to get video and camera, but no "he" wasn't revving up showing out or anything of the sort. As a matter of fact when the dang thing started "he" had started walking away from the bike, heard a little chug from the engine, next thing I...I mean "he" knows the bike is slamming into the wall and proceeding to tear **** up! The bike in question was an 06 not the 2011, the 2011 was parked about 6' away. Actually steered the runaway through about a 5' opening between the 2011 and the wall then down the other side, basically did a uuey around the 2011 before hitting the wall on the other side which gave "him" time to hit the kill switch. Never touched the 2011. Sounds wierd and crazy but it definitely happened.
Guess I'll be the oddball here....I hardy ever use the kill switch. Also using a wheel chock to park my bike when I'm home. Drive right into it when i pull in the garage. That all in itself would prevent something like that to happen...
Pretty darn crazy... One of those things that we had to be there to believe it, i guess.
I never use the kill switch. I feel it's there for emergency only. i never start the bike without pulling the clutch in and i don't know if it will turn over in gear be cause I've never tried it.
However, braking from the normal will usually cause you problems. What ever way you do it. Do it the same every time and you won't have any problems. It's when you do something different that problems pop up.
An like it was said if your going to listen to your bike radio use the ACC setting on the ignition switch.
I never use the kill switch. I leave mine in gear 95% of the time and put it into neutral before I start it. I always pull the clutch lever in before I start it. I learned this years ago when a neutral light didn't work all the time.
