HandleBar Internal Wiring
Old Jan 28, 2007 | 11:30 PM
rkc9999's Avatar
rkc9999
Default HandleBar Internal Wiring
Going to be changing handlebars this week. The old ones are internally wired and I'll be doing the same with the new.
I bought the Harley service manual thinking there would be info about running the wiring, but there doesn't seem to be anything except showing the connections for the hand controls in the headlight nacelle.
My question for someone who has done this before is, do you have to remove the wires from the connectors to get them to fit down the bars or is there some other connector or something that fits? Any help would be appreciated. If there is a place on the web showing detailed directionsthat would be great.
Old Jan 28, 2007 | 11:33 PM
rkc9999's Avatar
rkc9999
Default RE: HandleBar Internal Wiring
Oops, guess I should have mentioned it is a 2003 Road King Classic with 1-1/4 inch handlebars. [:'(]The new bars are 10 inch apes from Wild1.
Old Jan 28, 2007 | 11:47 PM
harley0711's Avatar
harley0711
It is actually very simple, hard to put in print... I will pm you with my number, call and I will walk you through it..
Old Jan 29, 2007 | 12:35 AM
ACRoadKing's Avatar
ACRoadKing
I just went through extending my wiring this weekend for my new Wild1 Chubby 508's for my RKC. I found this pdf file to be extremely helpful, especially when it came to the plugs and wire colors etc.
http://mysite.wanadoo-members.co.uk/hhog/rkbarswap.pdf
It was a rather simple job and I soldered and heatshrinked all connections. Just took a bit of time and patience. Good luck.
[align=center]
[/align]
Old Jan 29, 2007 | 12:39 AM
anubisss's Avatar
anubisss
Real quick. Remove tank bolts and slide tank back to gain access to wiring harness. Unplug harness. Take apart wring connector and make a diagram of how to put it b ack together. Then open your switch housings. I'm sure that other post has the rest, if not, feel free to pm me...
Old Jan 29, 2007 | 01:05 AM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: anubisss
Not for a Touring model.....The handlebar control connections are behind the fairing/nacelle.
Old Jan 29, 2007 | 01:48 AM
rkc9999's Avatar
rkc9999
Thanks ACRoadKing, those are great directions.
I'm thinking I can change the bars with removing the throttle cables and clutch cable from the switch housings. Of course I won't be able to bring the bars over to the workbench then.
Did you remove the headlight nacelle, is that necessary to get to the wiring harnesses?
Thanks to all who replied!
Old Jan 29, 2007 | 04:43 AM
xxxflhrci's Avatar
xxxflhrci
You have to remove the nacelle. It only takes about 10 minutes.
Old Jan 29, 2007 | 08:39 AM
Longtimegone's Avatar
Longtimegone
The link that ACRoadKing gave you is a very good article. You should also have a service manual available. There are some good tips on the Wild 1 site - one-piece handlebar clamp & don't use poly bushings. I put 10" apes on my RKC and when I lengthened the wiring, I went ahead and put about 7" additional kength on. It is a lot easier to deal with a couple of inches extra than to wind up just a little short. Dont' for get to stagger your solders.
Old Jan 29, 2007 | 09:48 AM
Grover's Avatar
Grover
Administrator Emeritus
Here is a link to replacing handlebars on a RK, complete with illustrations.
http://www.moccsplace.com/images/harley/hbar/hbar.htm
Hope this helps.
