oil leak
Old Nov 1, 2012 | 05:41 AM
captdanwh's Avatar
captdanwh
2nd Gear
Default oil leak
i just installed a new starter on my 2007 flhtc and just noticed a puddle of oil on my tranny after driving it for about a hour. i wiped it up and drove it 30 miles and it was there again. does anybody know what could cause this to just start after replacing the starter? i checked the starterbolts and they are tight , so i am a little confused. i had no leaks before installing the starter so the first thing i did was change the o ring on the dip stick but it did not stop the leak. i cannot see any leaks while it is sitting still so it has to be leaking while i ride. captdan
Old Nov 1, 2012 | 06:37 AM
dawg's Avatar
dawg
Did you properly install the starter to case o-ring?
Old Nov 1, 2012 | 11:35 AM
Bingee's Avatar
Bingee
I had a similar problem on my 2009 RKC after installing a HD 1.4kw chrome starter. It turned out that the bearing on the end of the starter clutch shaft did not have an oil seal on it. Turned out that none of the HD chrome starters had the seal. So the primary oil leaked into the starter assy and drained out onto the transmission. I replaced the starter clutch with one from All ***** which has the seal. That fixed the leak.
doc308
Shovelhead
Jun 30, 2019 07:38 PM
Harley5
Jun 16, 2019 11:44 AM
Jimbo45
Sep 2, 2015 07:55 PM
TexasVet
Jan 2, 2015 10:46 PM
2in2outhd
May 22, 2011 07:46 PM
