Antenna/CB Broken Stud
Old Nov 4, 2012 | 01:26 PM
Billf's Avatar
Billf
Default Antenna/CB Broken Stud
Looks like the CB stud that holds the CB antenna has broken off, along with the shorty antenna I've had on for years. The portion that's left on is way too small to get the antenna to screw onto it. Has anyone had this problem before and have a solution?
Old Nov 5, 2012 | 02:58 PM
lasvegasrick's Avatar
lasvegasrick
3.95 at harley replaced one for my sons 97 ultra
Old Nov 5, 2012 | 03:47 PM
Ultra89Rider's Avatar
Ultra89Rider
The antenna wire is attached to a small stud (3227) in the Tour Pak. This stud is just screwed in the antenna adapter stud (76260-89). Just go to the dealer and get the adapter. Then take the Tour Pak liner out. Take the wire off the antenna stud. Then unscrew the stud from the inside the Tour Pak wall. With this removed, you can pull the antenna adapter from the Light Bar. It is press in so it may take some effort to remove. When out, just insert the new adapter. Just look and see where the hole with the threads is located. Try to line it up with the hole in the TP wall. I took a Q-Tip stick to move the hole into the final position. Then just reinsert the antenna stud in the hole and tighten. Then attach the CB antenna wire. You now have a new place to attach the CB antenna.
Old Nov 5, 2012 | 09:41 PM
Billf's Avatar
Billf
Thanks for the reponses. Just picked up the new stud late this afternoon and will replace tomorrow.
Greg Di
2014-2024 Touring Models
20
Sep 25, 2017 08:46 PM
ERICKSON
May 29, 2015 02:12 PM
EasTexUltra12
Aug 10, 2014 02:33 PM
JONNIEROCK
Feb 27, 2014 03:18 PM
FINALEFFORT
Sep 26, 2012 10:57 PM
