Hi guys, I have just bought a 1997 Road king with a EFI 80ci evolution engine in it.
However it has considerably less power than my 02 Deuce had. I'm considering upgrading the engine so I get more power out of it.
What kind of big bore lots could I have installed into the bike to give me the power I want? Also, is there anything else I could get to increase the power either with/without a big bore kit.
Please be gentle with me here. I know very little about ports or bores, in fact I don't know a whole lot about engines in general. That's why I need the advice and then I'll have a mechanic do the work.
My 98 Evo Ultra Fuelie got the boost in power, but not from a big bore kit.
My particular build featured 10:1 Weisco pistons, EV 3030 cam, flowed heads and a Power Commander with a high flow air cleaner and a free flow exhaust, ( Pro Pipe.)
Very pleased, ran well with the Twin Cams and I kept it for 65,000 miles.
I've already got a kuryakyn hypercharger, power commander, and true duals pipes. I assumed that getting a bigger ci in the engine size would do what I need and I read that kita can be bought. Can a configuration like that be bought as a kit of some sort?
I suspect you can spend your money more efficiently than increasing the bore. I would start with cams and heads--remember if you go big cam you'll want the valve springs to go with it. I have long felt that the cam defines the personality of the motor!
Because I tour a lot, I stick with harley screaming eagle stuff, but there are cheaper ways to go. Keep in mind when guys talk about race tuners and dyno runs, that extra performance comes at the price of lower gas mileage. Also, the idea of revving the motor and then slamming a brake on it does not appeal to me.
I ride a '04 Electra glide, with these parts installed when the bike was new:SE heads, SE cams (high rpm cams, I forget the number!), Increased bore (88" to 95"), high compression pistons, and the H-D flash instead of the race tuner. The bike has a lively throttle response, gets over 40 mpg, and has been reliable for 113K miles. Not cheap, though.
Gentlemen please note: The OP has a 97 Evolution motor.
Most EVO upgrades involved cam, pistons and heads. Stroker kits and some big bore kits were/are available, but weren't that popular even in the Evolution days
Stiggy, how much was your particular configuration? Also, I forgot to mention that the bike apparently has stage 2. Of course I can't be sure. I went over all the paperwork I got with the bike and he kept really good record of all the work done to the bike and the only thing I see is that when he bought it, it came with a Vance and Hines fuel pak (I assume that's still in there), cam work, and it had bub pipes that were replaced with Big Gun II Slashers pipes.
Stage II on an EVO was a cam, Air Cleaner and a Stage II download as I recall. ( Stage I didn't upgrade the cam.)
Ported heads, pistons, cam and labor was around $1800. About 70 HP vs your stock 51.
Check out Headquarters website. They sell complete compatible kits consisting of all of the above to make things simple. They may still have a head exchange to save you a few $$$.
And a competent tech can install and tune your fuel pak accordingly.
Stiggy, thank you for all your help with this, and to everyone else that helped. After looking at Headquarters website I'm gonna be picking you the evo 85 kit from them and having it installed by my mechanic. Now all I need is the money to buy it, lol.
Thanks guys
With stock Evo cases you don't have much room for bigger bore, but you can stroke that motor to 89". That, a good cam, some head work, & a proper tune, & it will perform as good or better than most twin cams & do it without the heat. My FXR is done that way & I wish I could get it in my Road Glide frame. Stroking will give you the power without pushing the RPM limit so you retain reliability.
