Audio question
Old Nov 5, 2012 | 02:53 PM
pontiac69's Avatar
pontiac69
Default Audio question... Which amp between the 2 options.
I have 7 1/4 Rokker XT's and the stock HK headunit. Would you go with the Rockford fosgate Punch 300 watt 2 channel or the J&M 240 Watt Amp. Just looking at the 2 amps. The RF is 150 new shipped (but i will have to buy a 10 gauge amp install kit at 20 bucks) and the J&M is used for 200 shipped. I was going to get the RF 4 channel but saw it runs at 4 ohms. The 2 channel RF is 2 ohms at 150 watt per channel.
I know there are many options out there but my budget is tight. Just want to and am amp to push the Rokker speakers some more.
http://www.ebay.com/itm/251130741472...84.m1423.l2649
OR
2012 Street Glide
Old Nov 5, 2012 | 05:35 PM
jjnoble's Avatar
jjnoble
get the punch, and you don't need the 10 gauge install kit, but if you get an install kit from Crutchfield they add an additional year of warranty. but I think they charge more than $20, something like $45. If you buy your own stuff it will still cost you around $20, just the wire alone is pretty expensive. I don't know what you want to do about the install kit, but definitely get the rockford fosgate punch
Old Nov 5, 2012 | 05:49 PM
pontiac69's Avatar
pontiac69
I guess all i need is 10 gauge postive and negative wire with an inline fuse. Then some 18 gauge speaker wire and connectors. I think the amp install kit comes with all of that plus a set of rca jack which is not needed since the stock HK radio and amp dont take rca jacks.
Old Nov 5, 2012 | 05:55 PM
big papa AZ's Avatar
big papa AZ
I had the RF amp in my road glide, it out performed the RF speakers...
Old Nov 5, 2012 | 11:16 PM
pontiac69's Avatar
pontiac69
You"had" the RF amp. Does this mean you recommend it ?
Old Nov 6, 2012 | 08:41 AM
big papa AZ
I do recommend it, I am between bikes currently. Make sure the amp and speakers are compatible. If I remember, some speakers are 2 or 4 ohm, and some amps were only 2 or 4 ohm. I had the amp in the front fairing and it never fauted in the AZ heat.
oc357
Audio Systems
May 30, 2018 09:02 AM
zxport123
Audio Systems
Apr 18, 2017 05:08 PM
jamess71
Audio Systems
Jun 27, 2014 10:28 AM
roussfam
Audio Systems
Mar 28, 2013 06:43 PM
Miked053
Oct 19, 2012 01:58 PM
