battery drain
Old Nov 9, 2012 | 09:09 AM
2swild's Avatar
2swild
Default battery drain
anybody have their amp drain their battery down after the bike is shut off....i added a rf amp back in april and i believe it's draining my battery dead? any ideas, i need some help..
Old Nov 9, 2012 | 09:24 AM
JodyAmen's Avatar
JodyAmen
How old is the battery? Has the battery been tested? What year motorcycle?
To check for a battery drain or short disconnect the neg battery cable. Attach a test light from the neg cable to the neg post on the battery. On older non computer bikes you can use a regular test light. On newer computer bikes use a test light designed for it. If test light lights you have a short. If you think its from the amp disconnect it and test again. If light goes out you found your drain.
Old Nov 9, 2012 | 01:10 PM
2swild's Avatar
2swild
battery was tested @ the local stealer....it's great....2009 street glide....
Old Nov 9, 2012 | 01:52 PM
grbrown's Avatar
grbrown
If you wired it passed the ignition switch it probably will. Put a meter across the power leads to it while your ignition is switched off. If you measure anything then rewire it so it can only come on with the ignition.
Old Nov 9, 2012 | 05:26 PM
2swild's Avatar
2swild
i took the fairing off tonight...light on the amp only comes on when the bike is turned on....light goes back off when the ignition switch is turned off....don't know what to do...anybody got some more ideas..
Old Nov 9, 2012 | 08:26 PM
woodymaster's Avatar
woodymaster
5th Gear
take the neg off the the battery over night to see if it is the battery
Old Nov 9, 2012 | 10:26 PM
2swild's Avatar
2swild
on the charger now...might try a mutimeter meter tomarrow
Houtzy53
Electrical/Lighting/Alarm
Mar 29, 2016 10:11 PM
SeanG
Feb 25, 2016 10:11 AM
KJBennett
2014-2024 Touring Models
Jan 1, 2015 04:38 PM
RidemyEVO
EVO
Mar 20, 2011 08:04 PM
lagunatic
Ironhead
Oct 26, 2009 06:37 PM
