Ultra has no power two up. Please help
Old Nov 15, 2012 | 06:13 AM
  #31
d-streetglidr's Avatar
d-streetglidr
From: South Carolina-First to secede and hopefully the next.
Originally Posted by Kenney
From your description it sounds to me like you or a dealer needs to go over the bike top to bottom. Not adding a bunch of stuff just a good going over. Air filter clean, fuel filter replaced, spark plugs replaced, spark plug wires checked, etc., etc., etc.
That's some good advice there. Gives you a solid base to build on.
Old Nov 15, 2012 | 06:33 AM
  #32
speckfisher's Avatar
speckfisher
Time for Stage II, did you do Stage I?
Old Nov 15, 2012 | 06:40 AM
  #33
Notgrownup's Avatar
Notgrownup
I felt the same with mine at 50K... that is when i decided cams would be the trick...i was gonna do it anyway so i went for it. Although i did it all myself i did it all for about $350.00 i just checked the compression and it was fine... After 25000 with the cams i still feel satisfied with the extra oomph! it gave me...i am not ready to rebuild yet..i still have another year left on my ESP so i will leave it alone because the ESP won't cover " A little tired diagnosis" ... So for $350.00 it was my fix.
I am not slamming or denying any of the advice given here... all good advice...
If i had to do it over again i would do the same thing, maybe with a different set ofcams though...
To the OP, good luck and i hope you find the extra Oomph! you are looking for. I hope it's not to serious.
Old Nov 15, 2012 | 07:50 AM
  #34
JohnnyC's Avatar
JohnnyC
Pull the plugs and read them.
I'm going to guess they'll be blackened which will show a lean condition due to an intake leak. It's a common issue and would decline it's power under heavier loads.
If not, the compression test to check for worn out rings may answer your concern.
Old Nov 15, 2012 | 01:08 PM
  #35
dickey's Avatar
dickey
Originally Posted by AlaskaAviator
I would definitely check the air filter or replace it. If you have not had the cam adjusters checked you should also.
CAM ADJUSTERS!? WTH are those??
If they are blackened, it is showing a RICH condition. Lean will be white or light gray.
Old Nov 15, 2012 | 01:49 PM
  #36
JohnnyC's Avatar
JohnnyC
How did I get that wrong? Good catch. I need to go get some fresh air and put my flashers in, and then take a nice cold, chilly ride today. Need to flush out the cobwebs.
Old Nov 15, 2012 | 07:24 PM
  #37
Glockmeister's Avatar
Glockmeister
I'd do all the above and the cams...you'll find and fix the issues you are having and get even more return.
Good luck.
DeafLeopard
Motorcycles For Sale
Oct 7, 2011 08:44 PM
c50plus
Sep 6, 2011 03:04 PM
UltraNutZ
Oct 8, 2010 09:16 AM
c50plus
Oct 6, 2010 11:41 AM
zapps
Sep 26, 2010 09:52 PM
