2013 SG Tail Light Modification
Old Nov 13, 2012 | 06:07 AM
ghanu's Avatar
ghanu
Default 2013 SG Tail Light Modification
After all my riding buddies complained that my tail lights were hard to see in the sun because they blend in with the color of my 2013 Ember Red Sunglow SG, I decided to get the Custom Dynamics LED tail lights which helped but I wanted more. I added the cheap ineffective plastic accessory HD light and wasn't impressed with it so I figured I would cut the wire off of it and install a tail light from an 09 SG. I didn't want to cut the fender so I modified the tail light base so I could just stick it on with double sided tape, I hope I can find some 3M tape strong enough to hold it, maybe something automotive, otherwise I will go ahead and drill out the fender and bolt it on.
Attached Thumbnails 2013 SG Tail Light Modification-image.jpg   2013 SG Tail Light Modification-photo.jpg
Old Nov 13, 2012 | 07:37 AM
batman4706's Avatar
batman4706
Replace the tail light with a Bright *** Light, it fits in the same housing.
Old Nov 14, 2012 | 03:57 PM
RobsSG's Avatar
RobsSG
WOW now looks like it should...an 08 Street glide with a tail light, hummm. I guess they gave you a new frame so they kept the tail light. I got the tail light and fixed the frame issue with a bagger brace. 6 one way half dozen the other...I am headed to the BAL light for mine ASAP. I want folks to SEE MY BEHIND!
Old Nov 14, 2012 | 07:06 PM
Energy-Dude's Avatar
Energy-Dude
The tail light didn't go away until the 2010 models
Old Nov 14, 2012 | 08:45 PM
bobgv's Avatar
bobgv
I have the CD tail lights and swapped the bottom tribar with the HD brake/run LEDs and my friends think it puts out lots of light when braking but my SG is BBP. I think your changing the whole look of the bike with that light IMO. You should look into the led light bars from CD that installs between your bags and fender. Looks great and lights up real bright. Do a search here lots of info on it or call CD. Maybe somebody here can chime in with more info.
Old Nov 14, 2012 | 09:53 PM
rbferg's Avatar
rbferg
IMHO, the Tri-Bar Run/Brake Light Upgrade is a no-brainer for the '10 and later models. It should be standard equipment!
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Nov 15, 2012 | 05:08 AM
Glockmeister's Avatar
Glockmeister
And bolt that biotech on... The BAL is by far the best taillight out there IMHO.
Old Nov 15, 2012 | 06:01 AM
ghanu's Avatar
ghanu
The first mod I made was adding the HD tri-bar upgrade but it is not very noticeable in the daylight against the red bike. I was looking at the plasma rods at Biketoberfest when I purchased the LED clusters at the CD trailer but I prefer the look of the "old school" SG fender. I ended up using 3M VHB double sided tape to attach the tail light base to the fender, great stuff and I can remove it without damage to the fender if I change my mind.
Part numbers for the stock '09 tail light are 68066-99A Base and 68142-04 Lamp. For me it was $100 well spent.
EdandGrace
Jul 19, 2014 09:35 PM
goodryde04
Mar 12, 2011 07:16 AM
DukeofEarl
Sep 13, 2008 10:47 PM
Oldrider
Mar 18, 2008 01:21 PM
pauletich
Dec 12, 2007 05:16 PM
