Cams
Old Nov 17, 2012 | 04:48 PM
roaddr's Avatar
roaddr
Default Cams
Stock 2006 Ultra, PC, AN Stage2 AC, V & H Duals. My question is how much $ to put in gear drive cams ( Andrews 37), vs upgrade to hyd ten. with chain drive
Old Nov 17, 2012 | 05:04 PM
mrfikser's Avatar
mrfikser
first you need to check the run out of the crank shaft to see if you can (easily) use gear driven cams....
Old Nov 17, 2012 | 06:09 PM
roaddr's Avatar
roaddr
Right, If run out is ok will go with gear drive, if not then with upgraded cam plate with hyd. ten. , just wondering what the cost would be. Either way will put in new lifters and inner cam bearings, will use stock pushrods.
NELS
Jun 27, 2019 09:42 AM
Tcobfxdxt
Sep 1, 2014 08:52 AM
tomlescal
Exhaust System Topics
Apr 3, 2014 05:01 PM
Naz_Man
Jul 10, 2009 06:33 PM
broke joker
Apr 3, 2007 08:40 PM
