Popping Propipe update Tman 555 installed
Old Nov 23, 2012 | 12:50 PM
ral819's Avatar
ral819
Default Popping Propipe update Tman 555 installed
Just had the TMan 555 cam installed to see if it would straighten out a persistent pop I had with my FLHX. In getting the work done, they found a questionable Exhaust gasket that could have been causing the popping as well as missing bolt from the center Propipe bracket. Suspect was possible movement of the pipe that also contributed to the popping. I had 3 different dealers tell me there was no problem with the pipes previously. (Lesson learned, Check the Gaskets first and insure a good fit) Granted, the bolt could have loosened and fallen out after they checked ??? As far as the popping, I haven't heard any on the ride back home. I'll be keeping an ear on that but so far, the bike sounds louder, idles better, and the response is much better. My Dyno numbers came in lower than I thought they would be. The 92.72 HP seemed normal, Torque came in at 95.92. I'm going out here soon to give her a shake down cruise and see. My first impression was definitely a smile on the added power.
Attached Thumbnails Popping Propipe update Tman 555 installed-dyno-tman-555-cam.jpg
hollandhunter
Feb 24, 2017 06:33 PM
badger3x
2014-2024 Touring Models
Jun 19, 2014 09:06 PM
bulldog82098
Jul 10, 2013 07:57 PM
skully1200
Aug 17, 2011 04:51 PM
SparkyRKM
Sep 28, 2007 12:37 PM
