hole does not line up
Old Nov 25, 2012 | 02:15 PM
jmn1960's Avatar
jmn1960
Question hole does not line up
i recentley moved my bars down,, put it back together and the forks would not lock,everything else works,took it back apart aligned the switch and same thing,took it back apart and this time broke the plastic top of the switch that the nut goes on,, oh well ordered a new switch,,but upon removing the switch for replacement, i turned the forks all the way left, an the dhole where the locking pin comes out the bottom of the switch and is suposed to go into the hole in the frame,they are about 1/2 " off not from aligning with other,,any ideas?? i only moved the bars back 1/2",, no cable changes,,can not see any binding,,what would cause these holes from not lining up any more?? it should line up all the way to the left,,,the hole cant move i know,, so what the heel happened???
Old Nov 25, 2012 | 03:42 PM
jjnoble's Avatar
jjnoble
There are two things in align in the neck. Did you align both of them in sync?
Old Nov 25, 2012 | 04:02 PM
jmn1960's Avatar
jmn1960
never took anything loose but the two rear bar bolts to move the bars down,,thought the ing,switch was out of alignment,but it was ok,broke the top of switch,,ordered new one,,took switch off to replace,,turn bars to far left, and the two holes r about a half inch of becoming one hole for the lock pin to drop into,
Old Nov 26, 2012 | 01:57 PM
jmn1960's Avatar
jmn1960
well dont know what i did ,, but took it back apart AGAIN and put it back together AGAIN and it works again,,
Old Nov 26, 2012 | 02:01 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Sometimes best not to ask anymore questions if it eventually works!! Glad you got it back in shape.
teedoff65
Milwaukee Eight (M8)
Oct 1, 2017 07:18 PM
jmn1960
Mar 14, 2013 07:22 AM
julesdain
May 17, 2010 06:22 AM
northern lights wg
Jan 5, 2009 12:01 PM
MFA
Nov 27, 2007 10:13 AM
