Battery tender ?
Old Nov 27, 2012 | 01:15 PM
ZenGlide's Avatar
ZenGlide
Not to hijack the thread, but I plan to plug up my bike and noticed a difference in the connectors. The quick-connect connector on my Sears tender looks like the plug on my bike, but it's quite a bit smaller in size. Do they come in different sizes? What is the connector name, so I can find an adapter.
Thanks
Old Nov 27, 2012 | 02:01 PM
Jswerve's Avatar
Jswerve
Thanks
I run the sears 2amp 12v tender with no issues. Fitting is just snug takes a little Umph to push in.
Old Nov 27, 2012 | 02:04 PM
jimsflh's Avatar
jimsflh
Several I know swear by the plug it in every time you park it theory, a couple still have original batteries in their 04 and 06 bikes. you be the judge
Old Nov 27, 2012 | 02:05 PM
SLV's Avatar
SLV
Originally Posted by Buff58
My bike came with a battery tender. I have never used it as I ride it to work most every day.
I have to go out of town for a couple of weeks. Do I need to hook it up?
How long can it set without the alarm draining the battery?
Thanks
Buff
I can't answer the question about the security system, but using a tender daily will make a battery last a long long time (even if you ride daily)
Old Nov 27, 2012 | 02:24 PM
FBFletch's Avatar
FBFletch
I plug mine in even when I'm riding every day.
Prior to buying the battery tender I was replacing batteries every two years. My current battery was installed in 2007 and is still going strong.
A friend of mine who uses battery tenders religiously just replaced the original battery on his girlfriend's '02 Fatboy and his '05 Dyna is still on its original battery.
Pretty convincing case for always using a battery tender IMHO.
Old Nov 27, 2012 | 02:28 PM
SLV's Avatar
SLV
Sweet paint job Fletch!! I really dig that.
Old Nov 27, 2012 | 02:30 PM
02Deuces's Avatar
02Deuces
Originally Posted by CHIPPDOG77
If you have it, use it. Batteries are not cheap and using a tender wont hurt a thing.When i get off mine in the afternoon it gets plugged up whether it "needs" it or not.
same here....I look at it like this....I plug my cell phone up every day....Why not my bike? Help the charging system out a touch....When I hook it up it flashes RED for about 1 minute, then Green For another minute, then solid green (storage mode). Every day when I bust off my scoot, it seems like it doesn't even turn over it just starts....It's nice.
Old Nov 27, 2012 | 03:24 PM
Daddy-Rabbit's Avatar
Daddy-Rabbit
5th Gear
Default Battery Tender
I have the .75amp BT Jr, plugged my 04 RKC in any time the tires were not rolling. The original battery lasted until April of 2012. In June of 2012 the battery would have been in active service for 8 years. Then bought a Deka aftermarket battery, they supposedly mfg the HD battery, used same process of plugging in anytime I was not riding. 6-1/2 months later, I have a bad cell in the battery. They will not warranty the battery, six months is the warranty from Deka. Green Mountain Battery will not answer the phone & will not respond to emails, nor return calls. Bought another HD Original Battery & will BT it when I am not riding.
Old Nov 27, 2012 | 03:45 PM
Icetek's Avatar
Icetek
6th Gear
It may sound like "overkill" but ... Use the tender whenever your scooter is sitting in the garage ... On my older scooters (baggers) I was changing the batteries quite often ...after using the tender my 2009 is going on its' 5th season with no signs of failing ...
I have always used my tender when I parked the bikes.. 03, 05 and now an 09 in my old house's garages...if I was to go a few days without taking them out... not riding it was plugged in. At my new house I have to park outside so ran an extension cord for the tender most times. Then I put the bike on a Craftsman lift to work on brakes and tires and other stuff and it sat for more than a month without the tender because I forgot... Guess what.. when the work was done and wanted to test it out the battery would not start the bike and had to use a jumper battery. So after a 3 hour break-in ride (was only supposed to be a short 10 - 20 minute ride to check new wheels and brakes out but go figure....). Afterwards I put the tender back on on. Green light and it is back tending my battery. My Bike is also an 09 (FLHX) and has the stock battery. Needless to say i will figure out a way to get power near the bike so it is 'tended' while I'm not riding for at most a few days (max a week or two). A tender is the best thing in my opinion for your bike. Even before pipes and extra bling, etc...!!! as they are pretty cheap ($30+ for off market but I bought the HD one which cost more for the HD logo but probably work the same). Might look nice but if it doesn't start put a lamp shade on it and insure it as household furniture...
Old Nov 27, 2012 | 04:30 PM
ZenGlide's Avatar
ZenGlide
You were right. The one on the bike was a little bigger, but the contacts matched and it plugged right up with a little force. We must have the same Diehard charger. Mine will do either 12V/2A or 6V/4A. Thanks for your advice.
