SE comp gone bad!
Old Dec 1, 2012 | 11:45 AM
GPHDXLC's Avatar
GPHDXLC
What is the symptoms of a bad compensator.
Old Dec 1, 2012 | 11:53 AM
Mikind7's Avatar
Mikind7
Originally Posted by mike5380
I swapped mine out last year and now have about 10K on the SE comp. Using Formula+ and no issues at all.
+1 Formula +
Old Dec 1, 2012 | 12:12 PM
1Canuck's Avatar
1Canuck
Originally Posted by rickdell1
By the way, two springs were bad in the compensator when they pulled it apart.
how were two springs bad? have you seen them? The springs in my SE Comp are thick gauge concave washers ( perhaps others are too ). short of breaking how do they go bad, flatten out? I think there is more to this.
Old Dec 1, 2012 | 01:32 PM
Captain Itch's Avatar
Captain Itch
Sponsor
Glad I found this thread..Installed SE compensator and now have 30,000 miles on compensator It was starting fine still but sounded as if it was running dry.I had changed the fluid in the primary 400 miles ago.Pull the inspection plate fluid level is fine.Pull the drain plug and the magnet on drain plug lots of metal..Pull cover, and the surface of the cam ramps are pretty scarred up..What ya think ?Have only run Formula + in it. Hope you can see in the pictures..
__________________
www.Captain-Itch.com
Old Dec 1, 2012 | 01:36 PM
soft 02's Avatar
soft 02
Break in metal till the lobes lap into the ramps. Pulled mine at 60k. Little wear and no noise.
All polished up!
Old Dec 1, 2012 | 03:25 PM
kdfcogwheel's Avatar
kdfcogwheel
Had SE comp installed on my 2010 LTD 25k miles ago. Use only Formula +. No problems so far. I ride most days to/from work @ 100 miles per day.
Old Dec 1, 2012 | 03:27 PM
Captain Itch
Sponsor
Follow up..put it all back together and will just turn my mp3 player up louder..
Old Dec 1, 2012 | 03:46 PM
Tx_Rider's Avatar
Tx_Rider
Same here
Old Dec 1, 2012 | 05:43 PM
glide2005's Avatar
glide2005
I've had two OEM's go bad and replaced them with the SE Comp. Now it's makeing a ratteling noice now. Takeing it to my indy next week for that and new cams. I have only run Formula +. Indy says there is a friction washer in there that the stealer may have installed in the wrong place. I don't know, but I trust him more than the stealers. Will find out more next week.
Old Dec 1, 2012 | 07:49 PM
Lowcountry Joe's Avatar
Lowcountry Joe
That's absolute bull ****. If not for the Amsoil or the Redline, the damn thing would have probably went sooner. You have to remember that these dudes in the service dept are told by their store operations manager to do whatever is necessary to sell customers the HD lubrication products. That includes this kind of bull **** that is simply a cover for a poorly designed lubrication scheme in the SE compensator. Tell him to mind his own damn uninformed business.
