98 FLHT fork up-grades?
Old Dec 1, 2012 | 08:19 AM
Terminal Velocity's Avatar
Terminal Velocity
2nd Gear
Smile 98 FLHT fork up-grades?
OK, I need a little help. I have a 98 FLHT that I have put a new 113"Ultima in with a six speed and a 2" open belt primary. Now I'm doing a few more up grades to it when I get home from the Sand Box in a few weeks. I am putting a new wider swing arm on the rear but am wanting to also go with a 1" axle up front. Can I take a set of newer (02-08) front lowers and replace my older ones? Need the help before I spend some money and not be able to use them.
Thanks in advance for the help!
Old Dec 1, 2012 | 10:12 AM
dawg's Avatar
dawg
Swap out complete forks with internals and all. I'd suggest going with 06 or later.
Old Dec 1, 2012 | 11:29 AM
gsxrboy96's Avatar
gsxrboy96
Yes you can, its a straight swap, I've done both of my EVO bikes and one of them has the brembo upgrade with a newer wheel, all you have to do is the lowers, the tubes and springs are the same, best of luck, chad
Old Dec 1, 2012 | 12:30 PM
mrfuji's Avatar
mrfuji
Default 98 flht
hi. be a 98 will suggest to change the tube a the same time.b.k.rider have those 125.00 complete also have front chrome axel 40.00.lower are cheap on ebay. be sure you have the whell before buy lower. 08 up are 25 mm .mrfuji
Jagg11
16
Aug 2, 2017 05:04 PM
junior166745151
Aug 19, 2012 09:27 AM
fulldraw00
Apr 10, 2011 08:39 AM
FastGraf
Dec 2, 2010 11:14 AM
bloodlust
Jul 9, 2010 04:00 PM
