Rhineheart baffles install?
Old Dec 5, 2012 | 12:29 PM
rdc401's Avatar
rdc401
Default Rhineheart baffles install?
Have 3.5 rhinehearts.the high flow baffles stick out the end about 3 inches when l slip them in.do I need to trim them off or should iuse a piece of 2 by 4 on the end with a rubber hammer? Just don't want to mess up the pipes. Thanks
Old Dec 5, 2012 | 01:52 PM
2004Sierra's Avatar
2004Sierra
I installed the hi-flows in my 4" Rineharts a while back. The fit is a little snug, if not they would rattle. Make sure you are installing the inlet side of the baffle into the muffler body. Be careful tapping them in, use a piece of wood or plastic against the baffle and gently tap them in.
If you get to aggressive with the hammer you will deform the end and it won't fit into the end cap.
I had to carefully grind about 1/16" off of the back of my baffles in order for the end caps to fully seat against the muffler body. If you have to do this grind very little at a time, once you grind the metal off you can't put it back, and it may rattle.
It was a little bit of a pain in the butt but the results were great. I love the way the hi-flows sound.
Old Dec 5, 2012 | 02:20 PM
rdc401's Avatar
rdc401
Thanks, will try that.
Old Dec 5, 2012 | 02:37 PM
Lawdawg's Avatar
Lawdawg
Make sure it is the right pipe. Look for a serial number, it can be found on the hardware that holds the pipe to the bike. If the number starts with an R5 it will not fit. Rinehart changed manufacturers in 09' so the high flow won't fit the older ones. The high flow baffle is the same for the 3.5 and the 4 inch newer pipe.
My high flow won't fit my 3.5 so instead of sending them back I see 4 inches in my future :-)
Old Dec 5, 2012 | 02:40 PM
Lawdawg's Avatar
Lawdawg
Ok, before any sick and twisted comments are made. . . I see four inch pipes in the future for my bike.
I just needed to clarify.
Old Dec 5, 2012 | 03:32 PM
jus2anoyu's Avatar
jus2anoyu
Now That's funny right there!!
Old Dec 5, 2012 | 03:51 PM
rdc401's Avatar
rdc401
You were right it is the old rhinehearts, but did get them in had to cut them off the same length as the regular baffles, went right in sound great.auto tuner will adjust the afr if it needs to.
NWGlide
2014-2024 Touring Models
26
Jul 16, 2021 06:36 PM
RubberToe
Exhaust System Topics
Jul 17, 2015 11:58 AM
SoCalSoftailSlim
Dec 17, 2012 05:58 PM
dohadex
Oct 4, 2012 09:19 AM
apachethunder03
May 11, 2007 01:53 PM
