Where to buy switch?
Old Feb 2, 2007 | 07:07 PM
Abnmarine's Avatar
Abnmarine
Default RE: Where to buy switch?
I'll remember you if I need it.
Feeling a lot better. Staying indoors as much as possible. The cold air hurt the nose/breathing. Thanks for checking.
No problem on the install. This seems pretty simple. I think I will just go with what gabhart found.
ORIGINAL: Towpro
ORIGINAL: Abnmarine
Thanks everyone for the info. I'll start searching around to see who has what I am looking for. Will post when I do.
Hey bro, feeling better today....??? Hope your on the mend.
Now, let me know how the door opener went, so when I come to your house for the cam install we can knock that out to.....LOL [sm=joke.gif]
On a more serious note: I see more& more folks from the Northern Va. area, if you ever need a tow service, (hopefully not) don't hesitate to call me @ Willow Spring Towing,.......Rob.
Old Feb 2, 2007 | 10:45 PM
Potato_Potato's Avatar
Potato_Potato
You don't need a momentary switch - if fact you don't need an addtional switch of any kind - just wire it into your high beam switch. The circuitry in the remote sends one signal per press of the button there is no voltage draw if you keep the button pressed the little computer board in the remote acts as a momentary switch. Try this as an experiment. As you leave your house press & hold the remote button down your door will close normally. Keep it held down and drive around the block (in your cage) when you come back to your house (with the button still depressed) the door won't open unless you release the button & press it again. I wired mine near the head light using a small electric tie to keep the button pressed. You could also solder a jumper onto the board to accomplish the same thing. Very easy and very inexpensive mod.
Old Feb 3, 2007 | 12:43 AM
gabhart's Avatar
gabhart
ORIGINAL: tpmurray
I thought that what you are saying was due to a rotating code that all newer openers use for security reasons. This is directly from Genie's website: "...rolling code technology provides state-of-the-art security for your home by automatically changing your access code every time you push the remote control button. This prevents an unauthorized person from capturing the access code to your opener system and gaining entry to your garage."
So I would think you would want a momentary switch or a switch you would be willing to turn "off" after the door opens or closes to facilitate the rolling code.
Old Feb 3, 2007 | 12:47 AM
gabhart's Avatar
gabhart
ORIGINAL: Towpro
ORIGINAL: Abnmarine
I can vouch for Towpro. The company I work for uses them all the time. no issues.
Old Feb 3, 2007 | 06:14 AM
Abnmarine's Avatar
Abnmarine
I haven't met either of you two yet but damn. Between us and two other members who work in Stafford, we allneed to go riding together. [sm=icon_cheers.gif]
ORIGINAL: gabhart
ORIGINAL: Towpro
ORIGINAL: Abnmarine
Old Feb 3, 2007 | 11:54 AM
gabhart's Avatar
gabhart
ORIGINAL: Abnmarine
ORIGINAL: gabhart
ORIGINAL: Towpro
ORIGINAL: Abnmarine
Why, yes we do! [sm=biker.gif][sm=goodidea.gif]
Old Feb 3, 2007 | 05:46 PM
iclick's Avatar
iclick
This is by no means a switch identical to stock, but it works:
https://www.hdforums.com/m_1156433/tm.htm
Old Feb 3, 2007 | 05:51 PM
Abnmarine's Avatar
Abnmarine
Thanks for the info.
ORIGINAL: iclick
Old Feb 3, 2007 | 07:28 PM
BladeMan's Avatar
BladeMan
I did the same mod on my bike. I mounted the opener under my seat and used the acc switch to power it. The plug to the acc switch is already under the seat. All you need are some short pieces of wire. I flip my acc switch on before I hit the driveway and the door opens before I get to it. Then I just flip the switch off. I rapped the opener with some heavy self stick canvas and then velcroed it to the fender. It works great and its water-proof.
Old Feb 4, 2007 | 03:25 PM
Potato_Potato
In response to gabhart - I see your point on the rolling code but all you have to do is flick the high beam on then off.
