Throttle body sizing
Old Dec 7, 2012 | 08:48 PM
mfortkamp's Avatar
mfortkamp
Default Throttle body sizing
I have an 07 ultra classic. It is a 96" with a se air cleaner, stock tb, woods TW555 cams, stock heads and compression, Dragos dragula exhaust. I was wondering if I was to bore out my throttle body from 46 mm to 48 mm or even to 50 mm (if able) and do a port and polish of the intake runners if that would help me much. I know you can have too much intake and the low end will suffer but didn't know how much. I was looking at Fuel Moto's website and it looks like the newer bikes with the same cams and stock heads were making quite a bit more power than my bike.
thanks in advance
matt
Old Dec 7, 2012 | 08:52 PM
chuck3049's Avatar
chuck3049
You should call Frank Drago he has a great deal on what you are looking for, you already have his exhust. We will be back in the shop on monday, check out dragos web site.
Old Dec 7, 2012 | 09:15 PM
mkguitar's Avatar
mkguitar
re-think polishing the intake- turns out a 'pebble finish' will flow more air than a polished intake will.
Mike
Old Dec 7, 2012 | 11:03 PM
mike_oh's Avatar
mike_oh
thanks in advance
matt
50mm would work well......
Old Dec 8, 2012 | 06:55 PM
djl's Avatar
djl
I didn't think the 46mm TB can be bored to 50mm but did some digging and found that Johnsone Engineering Technology can bore the '06 and up 46mm TB to 51mm. Dyno testing shows power increases across the rpm range and not just at the upper end. Not huge gains but looks like 8HP/5TQ for $365 is fairly reasonable on a $$/HP-TQ basis.
Boring your cylinders to 103" and fitting a set of SE cast flat top pistons is also a good bang for the buck. About $400 if you DIY the job; that's about $40/TQ-HP; pretty cheap power.
Why not bore to 103" and bore the TB to 51mm?
Don't worry about dyno numbers you see around the internet; if you are happy with your bike; be happy and look for cost effective ways to get a bit more power. Check into changing the trans pulley; those six speeds were geared a bit tall. Dropping a tooth, or two, on the trans pulley will help as well.
Old Dec 8, 2012 | 07:34 PM
troop's Avatar
troop
Hey Don,
Maybe a dumb question but here goes. I see that J.E.T. and Dan Vance Racing bore/smooth TB's and then use a super epoxy to help shaping for optimum air flow. Any chance of epoxy loosening up/possibly entering into the motor? Like I said, might be dumb but will learning something
Old Dec 8, 2012 | 07:43 PM
mfortkamp's Avatar
mfortkamp
DJL thanks for the reply... I was thinking that the 08 and up have the 50mm tb and there is no difference in my 07 from the newer 96". I am a machinist by trade so i was thinking of boring my own tb out to what ever would be the best for no $. Wife is in nursing school right now and $ is tight otherwise I would be dropping on a Fuel Moto 107 with level b head and a big bore tb but for now the power mods i can do myself are going to have to be good enough. The only real reason i want to do this anyhow is my riding bud has a 04 with a 95 s and s kit and was talking trash bout how his 95 will blow my 96" away and i want him to really eat his words. not really that important but you know how it is. o and btw the only reason he put the 95 kit on is cuz i beat his 88" pretty bad and he couldn't take it.
Old Dec 9, 2012 | 10:05 AM
djl's Avatar
djl
Like Troop says, Vance and JET use epoxy to increase the velocity of the flow after boring to 51mm. JET had very disappointing results with just boring the TB to 51mm but kept working with the epoxy and finally got good results. Follow the link for the details.
http://www.johnsonenginetechnology.c...ttle-body.html
I don't know what your buddy is running in his 95"er but your problem is low compression. With stock heads and head gasket, your static compression is barely above 9:1 and CCP is below 170psi. You can fix that two ways, drop in a set of S&S 583s with an early intake close or pull your heads for mild cleanup, SERDI valve job, larger intake valve, new guide seals, machined for compression releases, decked to set static CR between 10.5-10.8 for a set of TMans 590 cams. You will say bye-bye to your buddy when you hit 3d gear.
The '07 were geard a bit tall; another inexpensive upgrade would be to change you trans pulley from 32T to 30T. Work intensive and, JMHO, but not worth the effort for 31T, it would have to be 32T for me. Drops highway cruise rpms but you can still run 75-80 at 3000-3200, much like 5th in the five speeds which, for me, is about perfect. You will need a new belt to drop two teeth.
You could also R/R the heads for a .030"head gasket and advance the 555s 4* and bring the torque in a earlier.
I know you said money was tight, so just throwing things at the wall for you to think about.
I know you said money was tight, just throwing some stuff at the wall for you to consider.
Old Dec 9, 2012 | 10:08 AM
djl's Avatar
djl
Originally Posted by troop
Hey Don,
Really don't know but I do know that a lot of the drag racing guys are using epoxy to shape intake manifold runners. I would guess that the epoxy these guys are using is very different from the epoxy we are familiar with. It would be worth a call to Dan Vance or JET to check out. I have to believe that they are pretty sure that it won't break down and get sucked into the engine.
flyboyron
Aug 23, 2018 11:03 AM
mfortkamp
Exhaust System Topics
11
Jan 4, 2013 05:06 AM
Born2cure
May 14, 2012 07:05 AM
beaureed445
Mar 14, 2009 05:54 PM
Jerry L
Aug 20, 2007 05:58 PM
