PCIII question?
Old Feb 2, 2007 | 11:46 PM
HogmanFLHX's Avatar
HogmanFLHX
Default PCIII question?
I got my PC from fuemoto and started installing it when I discovered the O2 sensor eliminators were not there. Called Jamie and he is sending them out. Apparently a lot of them were shipped short of the sensors.
Anyway, I finished the install. It runs ok but RPMs fluctuate (100rpm or so) at idle. Will it be ok to ride for a few days until sensors come in or will I do any damage?
Old Feb 3, 2007 | 12:56 AM
iclick's Avatar
iclick
Default RE: PCIII question?
I dunno, but would ask Jamie about that. I'm not sure how the EFI will react without the O² adapters provided in the PCIII kit. When you get your adapters, but sure to set your 0% and 100% throttle position.
Old Feb 3, 2007 | 01:07 AM
Neil's Avatar
Neil
I think it would all depnd on whether or not you are running the o2 sensors right now and if the PC3 is set up to run with them. If the answer to either question is no than I think it will be running too out of wack and you may run the risk of damage if things get too lean. Even though the new o2 system is a narrow system without them, and with the PC3 programmed to ignore them the ECM will be trying to make changes without the proper info. Just my 2 cents!
Neil
Old Feb 3, 2007 | 02:50 AM
hd2007's Avatar
hd2007
I would wait , they are eliminated for a reason. He should have them to you in a few days.
Old Feb 3, 2007 | 04:38 AM
HogmanFLHX's Avatar
HogmanFLHX
I have to wait anyway cuz I have to get someone to let me use their PC laptop. No software for Mac.
hdpearl70
Jan 26, 2009 09:49 AM
jackinthebox
Aug 17, 2008 11:10 AM
skratch
May 29, 2008 01:52 PM
robaube
Feb 21, 2008 08:04 AM
buellrider76
Jan 24, 2008 12:29 PM
