Hayden Primary Chain Tensioner - Pictures
You do need to be sure you have the B version and not the A version. See other thread I have listed for info.
In my list of jobs I once worked in heat treating and we toughened delrin by slow heating in hot oil. (we used in in masts for sliding bearings) It darken the material. Delrin,plastic,nylon (softer then the first two do not absorb oil)
Appears Hayden unlike Harley's adjuster is just a heavy spring loaded tensioner that stays tight all the time under spring pressure. Harley's has two heavy springs that take the chain down to what appears to be 3/8 play but if you push hard you will see it really is 1/2". The other long skinny spring is just the loader if wear gets over 1/2-5/8 slop it will jump one notch.
https://www.hdforums.com/forum/touri...-adjuster.html
I really cant give any good info on the Hayden until spring gets here so I can get some real miles on before I make a real report. As for tonight, I didn't feel much improvement if any. When I got back home and let it set and idle it still made that whining noise.
I don't think my IPB is bad because the noise is always there no matter if the clutch is in or out or in gear or neutral.
I will give a complete up=date this Spring............Winter Sucks.
I forgot to mention the stock shoe had deep cuts in the front part and they was a bit uneven with 17000 miles on it. I didn't like the looks of it.
Someone wrote the words 'Rocket Science' on the Forum one day ...
Combining chemicals, temperature and polymers its like crossing a street: you have to be conscious of what you're doing.
http://en.wikipedia.org/wiki/Space_S...-ring_concerns
In the end, the worst that can happen is a jammed transmission. It happened to me while accelerating out of a long curve (BMW R50S) and I don't want to experience this again.
) You also get lots of other applications you can explore, but under Photos you can set-up your Picasa web album. The space is free and I think they give you up to 1 gigabyte. So I have several different "albums" there, each containing photos of various projects, things, etc.To post a photo, simply right click on the photo, then left click on "copy image location". That places it on the windows "clipboard". You then can insert that into any post you make on this formum by using the icon available in advanced mode that looks like a yellow square with a little mountain in it named "Insert Image". When you click on that icon, you will get a hyperlink box. Simply place your cursor there over the http: and right click, then left click on Paste. That will past the link to the picture you just copied and when you do a preview of your message, you should see the picture.
You can post on this forum ANY picture you see on the internet. It can be anywhere. Just copy it's location and use the "insert image" icon in advanced mode to insert it's location hyperlink. Example: Michael Jackson
OK, maybe I should have used a different example.
