09 ultra wobble
Old Dec 16, 2012 | 12:40 PM
rooti's Avatar
rooti
check out this post..kinda scary
https://www.hdforums.com/forum/touri...-with-pic.html
Looks like before you take the fairing off, best to check the front wheel bearings
Old Dec 16, 2012 | 12:55 PM
itsahog's Avatar
itsahog
I am guessing this is the nut you are referring to? I have not checked it yet. It is not hand loose I did check that. If this is tight, then remove and go to Steering bearing I am presuming? I did the fall away test, it is awful hard to be sure all the looses connectors do not interfere. I get 3 solid swings with 4 "maybe 5" very small swings. With the 4th and 5th being maybe a inch and 1/2" respectfully.
Old Dec 16, 2012 | 01:37 PM
mtgriz's Avatar
mtgriz
What about alignment? I recall on my '01 this was an important check to make attire changing time. Wondering if it's the same with the new frame bikes.
itsahog's Avatar
itsahog
I have heard about the bearings and I watch them close. Will change soon with some decent non HD bearings soon. They are OK right now. I am confused right now on the manual. I removed all as said, but after I remove the stem nut, it shows the piece below it coming loose and exposing the bearing adjustment nut and it does not. It is one solid piece that appears to be attached to the forks and all. I have no idea how to access the bearing adjustment and the manual is incorrect unless I am reading something totally wrong.
Old Dec 16, 2012 | 01:42 PM
rooti's Avatar
rooti
I have a dyna and on mine it is a slotted washer under the head bolt. After you loosen the head bolt, you take a screwdriver and tap it in either direction
Have you taken the bolt completely off?
Old Dec 16, 2012 | 01:45 PM
robbie52's Avatar
robbie52
If the steering head bearings are really loose, you will be able to tell by the flex in front end at parking lot speeds.
Old Dec 16, 2012 | 01:48 PM
Streetrunner's Avatar
Streetrunner
I was under the impression that the swings counted were to be stop to stop but I may be wrong. Maybe someone can clarify.
Old Dec 16, 2012 | 02:14 PM
itsahog's Avatar
itsahog
I would post a video but I don't know how to do videos.
Old Dec 16, 2012 | 02:32 PM
itsahog's Avatar
itsahog
On my Ultra, it is a nut, not a bolt. Here is what I am looking at. I can't see where to adjust.
Hinson's Avatar
Hinson
If you are going to tear down to check the stem nut you might as well disconnect the clutch cable from lever and check the swing. With faring and radio off and steering stem nut torqued you want about 5 swings. With everything installed it should go down to 3 swings which is what the spec is I believe. Turn bars all the way left and let go to check the swings.
