103 air filter...
Old Dec 18, 2012 | 11:32 AM
Uncle Paul's Avatar
Uncle Paul
Default 103 air filter...
Does the 103 require an aftermarket high flow air filter.
I was told that engine comes with an intake that provides all the air the engine needs due to a larger throttle body.
Does that specific engine benefit from a higher flow filter, and at what RPM's does the improvement show up?
In the past, everybody did the air filter as part of a stage 1. Is this still a benefit?
Old Dec 18, 2012 | 11:49 AM
mkguitar's Avatar
mkguitar
the stock air cleaner is restrictive to noise emissions compliance.
a high flow air cleaner along with high flow mufflers will give 7 to 10 horsepower. ( "stage 1", which most often requires tuning compensation)
just air cleaner alone will see little benefit
some riders complain about the intake noise of a high flow air cleaner, a 'flutter" may be heard by the rider as well as the 'white noise" of air moving
almost all high flow air cleaners will allow more air flow than the motor demands ( stay away from the hype charger). most of the cast type backing plate incorporate an air horn which orders the air into the intake- turbulent air moves slower
in many cases the rider changes as they desire an oiled reusable filter over a disposable paper filter, such as a K&N or the similar which is used in the Ness Big Sucker.
The Ness is my bang for buck choice at about $120 on ebay from easternpc, also has a chrome backing plate which complements the motor- and an easier install in that the tank and the throttle body brace stay in place
an open air cleaner will see the biggest benefit at higher rpms, although the easy availability of air at low rpms may improve throttle response
mike
Old Dec 18, 2012 | 02:42 PM
Energy-Dude's Avatar
Energy-Dude
Originally Posted by Uncle Paul
Does the 103 require an aftermarket high flow air filter. All Stock Harleys run better with a free flowing air intake.
I was told that engine comes with an intake that provides all the air the engine needs due to a larger throttle body. The touring 103 has the same throttle body that the 96 has had since 2008.
Does that specific engine benefit from a higher flow filter, and at what RPM's does the improvement show up? All RPMs.
Yes!!
Gordon61
2018+ Softail Models
37
Oct 23, 2019 09:20 PM
Jimmy55TX
Oct 17, 2016 05:46 PM
JimGnitecki
Apr 20, 2014 03:13 PM
crock921
May 12, 2008 08:14 AM
yodal
Aug 13, 2005 03:06 AM
