Making clutch pull easier.
Old Dec 20, 2012 | 04:57 AM
luc.who's Avatar
luc.who
I too have arthritis in the hands. I picked up some racquetballs from wally world. I have been squeezing them and its been helping me a lot.
Old Dec 20, 2012 | 05:59 AM
ohioflhs's Avatar
ohioflhs
The clutch ramp on my 1990 FLHS was a 15° ramp. Most are 18°. The 15° was much easier to pull, but as someone here mentioned, it needs to be adjusted more precisely. I wore out a couple throwout bearings before I just put in an 18° ramp.
Old Dec 20, 2012 | 08:20 AM
PanJH's Avatar
PanJH
I tried the Easy Boy Lite kit, but found that the change in the lenght resulted in real quick engagement. I took it off and put on an AMP unit.http://www.amp-research.com/products...clutch-assist/
This really helped ... used it for about 6 months until my hand got better.
Old Dec 20, 2012 | 10:21 AM
mgmmgm's Avatar
mgmmgm
They probably cost way, way, more, but the hydraulic clutch on the CVO RKC pulls easy.
Wonder what the conversion price is to do that?
I have chronic tendinitis in my elbows L&I injury, my hands, forearms, wrists affected. Thankful for the cruise control.
Old Dec 20, 2012 | 10:59 AM
djl's Avatar
djl
Originally Posted by rodnock
Due to Arthritis I am beginning to feel some discomfort in my clutch hAND when riding in city traffic and having to change gears a lot. What can I do to make the clutch pull easier? It doesn't seem to pull any harder than normal.
Bike is a 97 FLHTC.
The AIM VPC is a bit pricey to reduce pull effort but it will do that. I would first try replaceing the cable with a replacement cable that is teflon lined; the early cables are not. Also, there is an H-D reduced effort ramp kit that combined with a new cable, might reduce the pull effort to a level that works and you won't need to spend the money for the VPC.
Some of the aftermarket reduced effort kits require some grinding in the case for clearance.
Old Dec 20, 2012 | 03:18 PM
greginNH's Avatar
greginNH
I had the Reduced Effort Clutch kit installed on my RKC - it is GREAT!
Old Dec 20, 2012 | 05:05 PM
vickers1's Avatar
vickers1
Originally Posted by okcjetmech
I put one of these on my '03. Easy install and a night and day difference.
Old Dec 20, 2012 | 05:16 PM
grbrown's Avatar
grbrown
I had a Clutchlite installed on my 1990 bike (similar to the other devices already mentioned). Earlier bikes like mine are more critical on getting adjustment just right, which I found unacceptable. I later installed a Diamondback cable and found pull is so much smoother and lighter that I removed the Clutchlite. For a 1997 bike you should be able to fit both and still get decent clutch release, plus much better lever effort.
Old Dec 20, 2012 | 07:05 PM
rodnock's Avatar
rodnock
I am gonna try the clutchlite first right after the holidays. My cable is in good shape and I keep it lubed so I'll wait on changing out the cable. Thanks to all for the responses.
Old Dec 20, 2012 | 07:44 PM
djl's Avatar
djl
You have to disconnect the cable to install the Cluthclite; might as well change cable to a teflon coated cable. A lubed cable won't compare with the light pull of the teflon lined cable; you will appreciate the difference.
