Headlight trim
Old Dec 25, 2012 | 06:34 PM
cweiss's Avatar
cweiss
actually mine fits well at the bottom but around the light there is a bunch of gaps. no probs though because it looks way better than the stock junk.
Old Dec 25, 2012 | 06:36 PM
Jswerve's Avatar
Jswerve
Love mine.
Hx3's Avatar
Hx3
Mine fits like yours (the OP's), not so good. It has to come off this weekend so I can put my Garmin mount on so I may screw with it and see if I can make it fit better.
Old Dec 25, 2012 | 06:56 PM
gdoc89's Avatar
gdoc89
Kind of a PITA to install but I was able to get it to go on by loosening the stock ring a bit before installing the trim ring.
Old Dec 25, 2012 | 07:18 PM
Uncle Paul's Avatar
Uncle Paul
Couple tricks to make it fit.
First, as instructions state, loosen the stock ring a bit.
Next, have a second person squeeze the sides in a bit as you tighten the threads.
If you do not have a second person, use a rubber fitted clamp to put some pressure on the sides as you tighten the threads.
If it does not fit perfectly, try to ignore it. Nobody will notice it unless they are into bezel inspecting.
Old Dec 25, 2012 | 11:51 PM
DBLX's Avatar
DBLX
Exactly why I returned mine. Didn't think I should have a piece of crap fitment on my beat. IMHO
Old Dec 26, 2012 | 05:19 AM
jus2anoyu's Avatar
jus2anoyu
I've had this part on 3 different bikes. Never got a perfect fit on any of them, but as others have said, it takes a close look to see that it doesn't fit that Well....
Old Dec 26, 2012 | 10:27 AM
RaceFace's Avatar
RaceFace
Mine fits like **** over the stock ring too. I saw on here somewhere that someone used an Irwin Quick-Grip and got the gap at the bottom to close. I tried it and still have a gap.....just not as bad.
Old Dec 26, 2012 | 11:49 AM
Jswerve's Avatar
Jswerve
I have a small gap in mine but I guess I'm not obsessed with it like so many others? Just doesn't bother me I really bought it for the looks from the side and not head on.
Old Dec 26, 2012 | 12:17 PM
IHC67's Avatar
IHC67
I have the visor trim with a Phase 7 Truck-lite. Fits ok, but I have the opposite problem, its tight as I can get it, no gap, and its kind of loose, I can turn it around the light. Though it doesnt seem to vibrate around while riding...yet.
