Won't start need some help
Old Dec 29, 2012 | 10:57 PM
Mark_H's Avatar
Mark_H
I had this same problem on my 97. All details were the same minus the security system obviously. I have a push button on my starter and the bike would fire up that way but not by the starter switch. Problem wound up being a broken wire in my handlebars coming from the start switch. And no, I had not done anything with my handlebars in the past two years.
With everything you checked I think it is either your start switch or a broken wire either in your bars or under the tank somewhere.
Old Dec 29, 2012 | 11:10 PM
aznomad's Avatar
aznomad
Check key fob batteries. make sure the key fob is near the bike.
Old Dec 31, 2012 | 01:15 PM
Moneywoes's Avatar
Moneywoes
I ruled out loose starter bolts, handlebar Run/Stop switch and the ignition switch when I was troublshooting the no turn over/no start condition.
I think the problem will eventually return as I didn't really do anything to fix it. I did change the start relay, but it will start now with either the new or old relay in it.
I'm pretty sure its going to be a broken wire to the start switch on the handlebar switch or a bad interconnect harness conection. I don't know how to check these if its not in a failed state. I am going to apply some dielectric grease to the fuses and relays. I'll also apply it to the harness connectors if I take the fairing cap off to further troubleshoot this.
I'm trying to decide if I want to chrome out the fork lowers and wheels via wiley shiney exchange http://www.willyshiny.com/ABOUT.html this would be a good time to get to the harness connectors for continuity checks. I have ordered this switch from dennis kirk so I don't get stranded somewhere if/when this no turn over/no start gremlin decided to visit again. https://www.denniskirk.com/201901.sku
Old Jun 13, 2013 | 11:26 AM
geobuc62's Avatar
geobuc62
Stage II
If your sure you have ohms passing through starter switch. You might have a BCM (Body control module)On your 08 that might be worth looking into. Check all Grounds. Some times it the dumb stuff that it so easily over looked
Old Jun 13, 2013 | 11:50 AM
kyote's Avatar
kyote
Lol.. this thread is over 6 months ago... I sure hope he got it fixed...
But for anyone else.. I put one of these on my starter.. works great!!
http://www.ebay.com/itm/CHROME-SOLEN...371927&vxp=mtr
WideGlideFever
Mar 4, 2020 05:33 PM
ghost183
Screamin Eagle CVO Models
11
May 28, 2018 10:49 AM
Visago22
Jun 23, 2014 06:36 AM
Jokr99
Jun 29, 2012 06:13 PM
Lex_Talionis
Nov 22, 2011 09:10 PM
