someone else started it...........................*
Old Dec 27, 2012 | 10:56 PM
  #51
05LowRider's Avatar
05LowRider
Talking No problem!
Originally Posted by kingomtn
O.K. guys, when I change the air, I lifted the bike on the jack so it wouldn't flat-spot the tires. When I got done, I had extra air left. Should I save it for later? How long will it be good to use?
Definitely save it for later! You never know when you might need it. I have stored my left over air for years at a time and used it without any problems. But I always store it in a climate controlled garage. This, I believe, is what makes all the difference!
Old Dec 27, 2012 | 11:11 PM
  #52
kennygsuperglide's Avatar
kennygsuperglide
How should I obtain 40 psi? I have one slider guage that maxis out at 60 and another, for my ATV that maxis out at 20. Could I apply the air untill the 60 maxis out and then release air, slowly, till the 20 is all, but maxed? would this be accurate enough to not throw a spoke?
Old Dec 28, 2012 | 01:40 AM
  #53
Razorback's Avatar
Razorback
Where have you guys been? Best place for air is here.
clicky>>> Kaleco
And dont forget new Heavy Duty Tire Beads. <<<clicky
If you gonna go to all the trouble at least do it right ferchrissakes.
Old Dec 28, 2012 | 04:28 AM
  #54
tbone108's Avatar
tbone108
I use smog air because i am a smoggy from the UK (its a uk thing you would have to google it) When all the air is gone the smog keeps the tyre up.
Old Dec 28, 2012 | 05:10 AM
  #55
Hunter1979's Avatar
Hunter1979
Do I need to pull a deep vacuum on the tire before installing the new air?
Old Dec 28, 2012 | 09:14 AM
  #56
silverglide2010's Avatar
silverglide2010
When replacing the air in the tires with the right color and pressure be sure to check the engines compression. If it's a little low you can use the left over air to boost it up. If you put in to much it may cause the muffler bearings to go bad. Take it from experience.
Old Dec 28, 2012 | 09:18 AM
  #57
3408pete's Avatar
3408pete
^^^^^^^ this is only if the engine has been bored out to standard bore
Old Dec 28, 2012 | 09:19 AM
  #58
patriot2500's Avatar
patriot2500
Blinker fluid change is a must!
Old Dec 28, 2012 | 09:25 AM
  #59
silverglide2010
Yes you are correct. Forgot to mention that.
Old Dec 28, 2012 | 09:53 AM
  #60
hardheaded's Avatar
hardheaded
Originally Posted by dickey
Never let your air get darker than 5-6.5 Roundel on the Lickford scale, otherwise you could experience flaking chrome inside your wheels, which isn't bad in & of itself, but it could cause you to develop deerbars on the barndells, resulting in a possible blowout & microfrasm at speed. Not a good thing to happen, especially if your atechme slubberdegullion has fresnic freen modulations on your slog bitsko fignut.
twist up another one and i'll be over.
