hand grips
Old Dec 28, 2012 | 06:50 AM
Timpechos's Avatar
Timpechos
Default hand grips
How difficult is it to replace hand grips on TBW bikes?
Old Dec 28, 2012 | 06:52 AM
Iceman24's Avatar
Iceman24
If you have a torx bit set, couple of tie wraps, small/thin strip of cardboard/plastic and about 30-minutes...very easy job.
Old Dec 28, 2012 | 06:58 AM
Timpechos's Avatar
Timpechos
are there any tricks to replacing the grips on TBW
Old Dec 28, 2012 | 07:10 AM
Iceman24's Avatar
Iceman24
TBW-side is pretty much slip on/off & the inner grip matches w/gears on TBW control end. Here's some tips, from my experiences w/grip swap:
1. Make sure you protect the Right-side brake switch (between handle & controls) with small piece of cardboard/plastic. Brake/damage it & you'll need to replace it as well.
2. Start with the "easy" side (Left) so you get the jist of what's involved. Might have to "cut" off your Left grip (glued).
3. Make sure you don't "pinch" any of the control wires & carefully tighten the control screws (they will snap heads - I know).
4. Hang your controls from bars with a couple of tie-wraps...don't want to dangle from wires/lines.
5. ALWAYS cover your tank with large bath towel. If there's any chance of dropping/denting/scratching your tins...it will happen. Nice thick bath towel ensures you're protected from these small hazards while wrench'n.
Other than that, follow the directions and enjoy.
Old Dec 28, 2012 | 07:20 AM
TKDKurt's Avatar
TKDKurt
Especially #1! (See the manual about inserting the cardboard shim after pulling the brake handle in.) #4 sounds like a good idea, but I just let mine hang. #5 is always a good idea (Murphy's Rules are inviolable.)
I did not have to cut off my left grip. Just one hard twist and the glue broke loose. There isn't much glue holding on the stock grips. If the bike already has aftermarket grips, the installer of those grips may have used more.
N1265
Dec 27, 2015 09:21 AM
blackpullet
Mar 17, 2011 06:24 AM
maddoggreene
Jan 31, 2008 06:53 PM
first dyna 07
Aug 3, 2007 02:25 PM
harley0711
General Topics/Tech Tips
Jul 24, 2006 05:22 PM
