The 103 which includes factory automatic compression releases was optional in 2011. Called the power pack, it included the bigger engine, oil cooler, abs and cruise control. This engine was standard on 12 and later.
Also, all 2011 and later touring bikes got the screamin eagle compensator.
Sorry, your absolutely correct, I forgot that I did order mine with the optional power pack. The memory ain't what it used to be. What's the difference between the Screaming Eagle compensator and the pryor compensator? What is a compensator?
O.k, I learned about the Screaming Eagle compensator upgrade for 2011 ( Thank you Lowcountry Joe ) but why is it your opinion that 2011 is the best bar none, I'm assuming that 2012s and '13s still have the S.E. Compensator. Are there other reasons?
