Please help me
Old Dec 31, 2012 | 10:11 PM
justincollins1's Avatar
justincollins1
Default Please help me
I recently installed v&h slip ons and am getting some minor decel popping. I have done research but have not found something to solve it. I have the pc III and a se ac. Thanks in advance guys. Are these minor pops anything to worry about.
Old Dec 31, 2012 | 10:13 PM
Juan L's Avatar
Juan L
Moderator
Just attention getters!
Old Dec 31, 2012 | 10:28 PM
justincollins1
Yea man they just bother me. Would you worry about them. Do you have any decel popping.
Old Dec 31, 2012 | 10:29 PM
djbiker's Avatar
djbiker
Sounds like you are still a bit lean, check your program in the PCIII
Old Dec 31, 2012 | 10:35 PM
Lowcountry Joe's Avatar
Lowcountry Joe
It's either your tune or possibly an exhaust leak. Did you use new muffler clamps and torque them to specs? Muffler clamps are intended for one time use, not re-use over and over. What pipes did you have on before? I am assuming that you had no popping with them.
justincollins1
Do you would up the numbers in the 0% section?
Old Dec 31, 2012 | 10:37 PM
justincollins1
I had stock mufflers on so I would not be able to hear the pops if there were any. I have checked and all 4 bolts are tight. So no exhaust leak
Old Dec 31, 2012 | 10:38 PM
RoadKing2438's Avatar
RoadKing2438
Could be a couple different things. Like djbiker said, might need a new map. Also check to see if you have an exhaust leak. Just because all the bolts are tight doesn't mean you don't have a leak. There are tons of threads on here about the subject. Do a quick search and you might find some useful info.
Old Dec 31, 2012 | 10:44 PM
justincollins1
I got the map from fuel moto so you would think it would be good.
Old Dec 31, 2012 | 11:46 PM
mikelikesbikes's Avatar
mikelikesbikes
I have an 01 carb Road King so not nearly as complicated as most bikes here but had decel popping since I got the bike 60K ago. Recently had cans replaced and now no more backfire. Check all bolts/connections. Being too **** may not be that bad.
