Touring pc maps
Old Feb 7, 2007 | 04:56 PM
bountyhunter's Avatar
bountyhunter
Default RE: Touring pc maps
Time to look for a dyno shop and get your bike tuned by a pro...well worth it!
Old Feb 7, 2007 | 09:36 PM
ORCUTTHD's Avatar
ORCUTTHD
Call Jamie at www.fuelmotousa.com
Old Feb 8, 2007 | 12:34 AM
SteveO's Avatar
SteveO
Have you tried a "0" map to see if it is the PC? I also assume you have the throttle position set properly? Turn off the acc pump if you are using it, it will goof up the map, set both cylinder trims to "0". And I assume you are using the 9 volt battery when installing your program from your laptop? Reinstall your map after all the above. The Dyno Jet maps are usually right on.
Also,the waythe PCwiring connectors aremounted allows water into the wiring harness, the ECM to the PClll connection.Got mine wet and it banged and popped around 2000 RPM for days. After trying several maps and going to a "0" program I pulled the harness apart and it had water in it. Dried it out with a hair dryer put electrical silicone on all the connections. Also tried to change the mounting so the harness would not lay horizontal and water stand in it.
You may have a problem with the PClll and it may need to be sent back to the factory for repair.
The folks at Dyno Jet are real helpful on troubleshooting problems.
Just a thought.
SteveO
markorb
2014-2024 Touring Models
13
May 1, 2025 11:18 PM
OCD
Sep 4, 2011 11:50 PM
maineultraclassic
May 4, 2006 10:18 AM
SMSgt B
May 3, 2006 11:28 PM
maineultraclassic
Exhaust System Topics
Apr 26, 2006 07:00 PM
