Touring pc maps
Old Feb 4, 2007 | 06:38 PM
TickTock's Avatar
TickTock
Default Touring pc maps
Looking for a custom pc map on a 2007 touring with rineharts and a big sucker. Thought I'd check this thread to see if anyone might have one they could share. I have a knocking noise off of idle that I believe is in my custom map and wanted to compare mine agains someone else's to see if there are any vast differences.
Anyone???
Old Feb 5, 2007 | 09:50 AM
TickTock's Avatar
TickTock
Default RE: Touring pc maps
ttt
Old Feb 5, 2007 | 09:55 AM
bountyhunter's Avatar
bountyhunter
m812-020
Old Feb 5, 2007 | 11:29 AM
Hardly Dangerous's Avatar
Hardly Dangerous
What map are you using now? Why not go to Power Commanders website and find something close and tweak it from there.
Old Feb 5, 2007 | 12:20 PM
TickTock's Avatar
TickTock
The power commander map did not work and neither did my custom map. The problem is a slight burp when you twist the throttle back at idle. Happens in the 40 percent range. In the PC software a CTRL-T will highlight the current cell and show where the throttle position and RPM numbers are. When I did this, sometimes it went down the 0 throttle column and sometimes shot over to the 20-40 pct throttle at 1750 RPM range. I have added fuel, subtracted fuel all to no avail. Perhaps it is a PC problem, but I was hoping to compare to something else just to see if there is a difference in fuel other than where mine is mapped and different from the m812-020 map from PC.
Old Feb 5, 2007 | 03:06 PM
TickTock's Avatar
TickTock
ttt
Old Feb 6, 2007 | 07:57 AM
TickTock's Avatar
TickTock
ttt
Old Feb 6, 2007 | 09:25 AM
pittguy's Avatar
pittguy
Perhaps you have a sensor problem or you may have just joined those of us w/this so called normal noise.
Old Feb 6, 2007 | 11:07 PM
SteveO's Avatar
SteveO
I think PC just produced a map for the 07 with your exhaust and filter. I had a couple of problems in the past and the PC folks were very helpful, fixed the problem.
Old Feb 7, 2007 | 04:15 PM
TickTock's Avatar
TickTock
I started with that one and went with a custom map. Still no luck.
