EG Sidestand Question?
Old Jan 7, 2013 | 09:42 PM
bent trix's Avatar
bent trix
Default EG Sidestand Question?
The sidestand doesn't extend as far as I would like when in the locked position. Is the tab that locks the stand in place adjustable?
Thought I would ask before I tore it apart.
Thanks in advance!
Don
Old Jan 7, 2013 | 09:58 PM
stro1965's Avatar
stro1965
Nope.
Old Jan 7, 2013 | 10:21 PM
bent trix's Avatar
bent trix
That's not what I wanted to hear..lol Thanks for the reply. Im glad that I asked before wasting the to take it apart, just to find out that it's a single position.
Old Jan 7, 2013 | 10:46 PM
Pumba11's Avatar
Pumba11
He's right.
Old Jan 7, 2013 | 10:49 PM
mkguitar's Avatar
mkguitar
does that mean the bike is lowered, so you no longer get a good lean angle on the stock jiffystand?
if so, you can bend the jiffy,
heat it cherry red, bend it. spray it with new black paint
mike
Old Jan 8, 2013 | 12:36 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Do you want the bike to stand more straight up when it is on the kickstand?
Old Jan 8, 2013 | 12:56 AM
bent trix's Avatar
bent trix
mike
Hey Mike, Good idea on the bend. If it needed a bend in it, I would blow the dust off my tubing bender and message it a bit.
Sorry about that - I should have been more clear with my question.
When I kick the stand out and set the bike on it. The "lock" tab locks but the stand kicks out less than 90 degrees, about 80 degree (from the rear of the bike).
Maybe I am accustom to the way a dirt bike or other street bikes sidestands are. They usually point towards the front of the bike when down. Mine points towards the rear a bit. Almost as if the bike has rolled forward while on the stand.
Since it cant be adjusted, I guess I can pull it off and run a bead down the tab to tighten up the variance between the tab and channel.
I hope this explains my scenario a little more clearly.
Oh, I have another question while we're on topic. Why are they called a "Jiffy" stand? Is it because a guy named Jiffy came up with the idea/design, or perhaps it's because it's a locking stand?
Old Jan 8, 2013 | 01:41 AM
mkguitar's Avatar
mkguitar
jiffy because it is fast.
the original stand deign was a flattened " U" shape bolted to the rear of the bike near the rear axle.
this U extended to the rear and was clipped to the rear fender.
when stopped, the rider would balance the bike and move to the rear...with one foot kicking the stand down from it's clip, and with both hands pulling ( lifting) the rear of the bike up onto the stand until it went over center and locked.
um, so the jiffy is a good idea.
until recently, the "swingarm" was always referred to as a "rear fork"
milwaukee-beer...I guess.
here's a pic of my '53- the stand can be see underneath the brightwork bumper- the 2 ribbed flatstock pieces, and the horizontal bar stock
you can also make out the clips which hole it in place.
i don't use this feature often ( but handy if changing a tire...that is why the fenders were hinged)
the package rack on these bikes was an option- imagine lifting with out it!, you'd have to grab the fender edges ( and mine has bags in the way.
my rack is identical to the H-D ( and Indian) but mine is a "National"- there is no record of the original owner adding it- he kept notes on everything, so it "may" have been supplied by HD if they were short on inventory
Just guessing from my living room that the stand on my 1995 FLHTC went to about 135ş
and the stand on my 2009 FLHTC goes to maybe 120ş.
but it is certainly forward of 90ş.
mine is down an inch in the rear using street glide shocks.
but it very stable when parked, I do always leave it in gear when parked.
in my garage I have a wedge under the jiffy to make the bike stand up straighter as it is crowded with 5 bikes in there...
Mike
Old Jan 8, 2013 | 05:28 AM
B00001's Avatar
B00001
I know what you mean here. Mine does the same. Looks quite precarious to me but so far it has been fine.
|V|egaman
Feb 15, 2011 09:58 AM
jgreenwell
Oct 14, 2007 09:55 AM
Dallastx
Aug 1, 2007 07:56 PM
