Need some help installing Jackpot header...
Old Jan 12, 2013 | 05:01 PM
Stang951's Avatar
Stang951
I got mine used from a guy here on the forums. His was an 11 model and was using the 12m bungs. He had plugs in the 18mm bungs that I have to use on my 09. One gave me problems and I had to let it soak in wd40 for a few hours, and it was still a B*^h to get out. I don't think that I tweaked anything but I am not discrediting that possibility just yet.
Old Jan 12, 2013 | 05:26 PM
WI Bob's Avatar
WI Bob
I have done this dozens of times. It is finesse and not force.
One key is to tip the bottom out as you bring the header towards the cylinders first. It will actually fit in there without touching the fins if you are careful.
The next step as you move the bottom in towards the bike is to be sure the header tab gets below the tranny bracket.
Then go back and slide the flanges on the bolts up top.
Start all the bolts and then tighten as per the manual.
Easy on those exhaust flange bolts, 100 inch pounds is enough.
Save some headaches and use the stock exhaust gaskets. The header was designed for them. I have tried others, inculding the SE and the stock are best for fit and performance.
Old Jan 12, 2013 | 06:06 PM
Stang951's Avatar
Stang951
I called my mechanic back and told him that there are only 2 options (1) the headers is not in the head properly or (2) the header is tweaked. He put me on speaker and did a test (to him) and tightened on the header bolts at the heads. The bottom kicked out away from the bike even further. Not sure what to think, but I am going to try and go over there tomorrow...if the weather is nasty...if not he is going to go riding. I can't blame him. Hopefully he was just having a rough day and it goes on properly next time he tries it.
Old Jan 12, 2013 | 06:40 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by Stang951
Not to hijack the thread but my mechanic just called and he is having some trouble installing my headpipe on my 09. He has the bolts started in the heads (not tightened but on) and the support at the transmission will no slide under the tab. Has anyone had this problem? Is there a step that he is not following.
He was going to try and grid the bottom of the tab so that it would fit on top instead of on bottom, but I don't think that is a good idea. I did have a hell of a time getting the old plugs out of one of the headers. Is it possible I tweaked them when I was wrenching it out?
When installing the pipe it is essential that the bracket is first placed under the trans bracket, you can then fit the flanges at the exhaust port and everything falls right into place. If you try to install the flanges first it will not fit, as the bracket on the pipe will be on the wrong side of the trans mount. If your mechanic has it installed with the bracket on the incorrect side of the trans bracket he needs to remove the pipe completely, upon reassembly when he puts the pipe up to the bike put the mount UNDER the trans bracket, and then connect the flanges at the cylinder heads. If any additional assistance is required we can be contacted at 920-423-3309
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jan 12, 2013 | 09:54 PM
cbumdumb's Avatar
cbumdumb
damn made me go check mine and I got it right lol
Old Jan 15, 2013 | 09:52 PM
Stang951's Avatar
Stang951
Jamie, I have to give you and your team serious credit. Posting on the weekend with advice to install one of your pipes secondhand is the reason I will continue to keep buying from you!!
My mechanic followed your instructions and it went in easy! Thanks again.
Old Jan 16, 2013 | 09:58 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Thank you for the update and continued support
Old Jan 18, 2013 | 04:44 PM
drspencer's Avatar
drspencer
Jamie-What exhaust gaskets do you recommend using?
I used the stock HD exhaust gaskets with your head pipe, but when I later removed the pipe do do cams, I noticed that the stock exhaust gaskets were crushed, obstructing the flow of exhaust gases (imagine what a clogged artery looks like).
Some Folks here say to only use the SE gaskets, others say to only use the stock HD tapered gaskets.
Which do you recommend for this application?
Thanks
Old Jan 19, 2013 | 08:34 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Thanks
Did you torque them to HD specs, 100-115 in/lbs?
Since these aftermarket pipes are not tapered like the HD pipes, I hope those torque specs are correct because I just installed MGS Duals and used the 100 in/lb spec for the first go around until I can heat cycle them a few times.
Maybe FM can chime in as far as what they torque the flange nuts to..........
Old Jan 19, 2013 | 10:59 AM
Griff012FLHX's Avatar
Griff012FLHX
Read all of the post above they answer your questions.
Stock gaskets are the ones to use.
100 in/pounds.
sincitychoppa
Apr 26, 2015 08:29 PM
Port Dawg
Aug 27, 2012 03:35 PM
osirisdean
May 15, 2011 11:06 AM
MaxShovel
Shovelhead
Aug 29, 2008 03:50 PM
Jezcruzen
Exhaust System Topics
Jan 25, 2006 09:50 PM
