Friends dont let friends use 255 cams.
Do yourself a favor and choose a reputable engine builder and follow their recommended engine packages. If you want the most out of your engine bore it out to a 107 and up the compression to 10:5 to 1 and install a cam that works with that compression ratio. With the proper pipe and tune you should be around 100 hp 110 torque.
After installing the Andrews 57H in my 2010 103" motor, I can honestly say that I cannot feel any additional heat at all. Since they have been in for only a few weeks, I have not had them in summer here yet. But, judging from what I am feeling on these moderate days of 60ish degrees or so, it almost seems cooler.
The ramps on the 57Hs are much steeper than stock and the lobes are broader, so the heat is not being held in the heads nearly as long as stock. So based on the cam design and tuning parameters, you can enjoy the increased torque with the same or may be less heat.
If you stay with the HD cams, you may get a different result.
Here's a pic of the 57H grinds compared to the pitiful stock cams from my 103. Apart from the poor stock cam construction, take a look at the shape differences in the lobes. I think it's a pretty stunning comparison.
EDIT: sorry about the long, and OT post here, but this also includes info about your supposed choice of cams, the SE255.
Funny, I did bolt ons, se 255 cams, and a TTS tune from the TTS list and the durned thing runs very well. I must have done something wrong according to some folks to have this kind of success with a "bad" cam! The roll on is great, with power from the bottom of the power curve well up to six grand. It isn't as strong up above 5,000 as some, but does very well for a mild upgrade that won't beat up the valvetrain like some aftermarket cams. And that part (beating up the valvetrain) is VERY important to me.
On the heat issue, sure it will build heat, but it is less on my 2011 Limited than it was stock! The tune helps a lot, and it is as much how you ride as well. Run the crap out of it and pull up to a light and it will be hot! Duh! I have 17,000 miles on this 255/Limited 103 combo and don't regret it at all.
Any cam you put in it that will hit a higher torque peak will lose it somewhere. Most performance cams will run a tighter lobe seperation and the result is less roll on torque up to somewhere around 2500 rpm. They pull harder there , but have sacrificed some of that low speed roll on I like so much. So the choice is yours on cams. The 255 is a great cam for the $$, usually $150 used. A rollercam that shows no obvious signs of ware is just fine for a new bike as well. There just isn't a problem with ware with them.
If you have at least 25 degrees of overlap and a good tune,you good to go............
Now theres an answer with some merit. Generally speaking most aftermarket cams have timing priofiles that are not "EPA" compliant, They are designed for max power not max efficiency. They allow a bigger charge to come in which helps to cool the combustion chamber from the previous burnt charge, and they keep the charge inside the combustion chamber for a shorter period which means less "heat sink" both contribute to a slightly cooler running motor.
, and I'm moving alot more weight with the Trike. I've surprised more than one 110 CVO with my signature combo.
The reason I ask is because i'm trying to decide whether or not to put a cam in. Living in Florida I'm always concerned about anything that adds extra heat. I'm not dissatisfied with my bikes performance, but after reading how much everyone loves the improvement, I of course am considering it. With a PV and Fuel Moto tune, exhaust and a/c, it seems to run great. Would like more torque, just don't want to trade reliability for it.
I live in Ohio and have been running the 103" stage 2 with SE 255 cams for over 10,000 miles. It gets plenty hot here in the summer but not as hot as where you are for sure! I love how my bike runs and I don't get the heat off of it that I got off a 2013 Ultra I recently rented while on vacation in Hawaii. That damn cat is a monster! But as you are not running stock exhaust that is not an issue for you. A bump in performance is great and a cam like a Woods 222 or Andrews 48 or 57 or S&S 551 or Zippers 525 or 527 would go along way in adding enjoyment to your riding and actually, if when in there, you replaced the OEM cam bearings with Torringtons, your reliability factor will increase over stock and would run cooler than stock cams. I did my engine in Oct 2010 and the options were not as numerous then as now. If I was doing it now, I would be running something other than what I am but I am not dissatisfied enough with what I have to warrant changing cams and re-tuning. In short, for where you live, I would stay away from the SE 255 cams and go with one of the others listed if you are bound on making a change. The 255's are popular torque cams but they are not the best choice especially for a 103". Throw a set of those 222's in there and prepare to grin! Good luck!
If the "root" of your concern is heat, you could use the FCS, one of the cheapest and most effective heat management products you can buy. It will keep your motor cool.
