Garage heaters
Old Jan 16, 2013 | 08:55 AM
mathew2172's Avatar
mathew2172
Default Garage heaters
What kind of garage heaters is everyone useing. I cant get gas run to my garage so im looking at buying either a propane portable heater or a electric one. Any ideas?
Old Jan 16, 2013 | 08:59 AM
Pitbull2411's Avatar
Pitbull2411
I've been kicking this idea around as well. If your garage is not completely insulated I would start there. Also, any decent electric heater may require some work getting the appropriate power to your garage. If you're just wanting to warm up the garage while working I'd go the portable route, but if you want seasonal long term heat research a better solution.
Old Jan 16, 2013 | 09:01 AM
tincup64's Avatar
tincup64
i had the same issue in my house south of boston. i bought one of these based upon a the garage journals recommendations. it's electric, but works really good. 1 unit heats a 25 x 25 attached gargage perfectly for my needs. when it's really cold - i just be sure to turn it on an hour or two before i go out there to work. i've considered putting a second one in - but haven't had the need yet.
http://www.greenhousemegastore.com/p...nhouse-heating
good luck - tin
KCFLHRC's Avatar
KCFLHRC
Definitely electric, propane will have to be vented.
Old Jan 16, 2013 | 09:04 AM
KCFLHRC's Avatar
KCFLHRC
good luck - tin
What's the input voltage on that unit? Standard 120 volt or does it need 220? The description doesn't really say. Looks like it is 220 when you choose the pull down for model.
roadking2014's Avatar
roadking2014
shoot, go with a Herman Nelson.
Old Jan 16, 2013 | 09:05 AM
davidsdad's Avatar
davidsdad
I use a "Torpedo" heater, it burns kerosene and 120v blower. Just make sure you either leave a window or door open just a little bit to keep fresh air in. I've been using mine for years.
Much like this one below from Sears.
http://www.sears.com/world-marketing...&blockType=G12
Old Jan 16, 2013 | 09:10 AM
KSGLIDEGUY's Avatar
KSGLIDEGUY
I have 2 heaters, a kerosene and a propane. Neither of them have a fan so no need for electricity. I go out and turn them on for 30 min and I can work in a t-shirt.
Old Jan 16, 2013 | 09:12 AM
tincup64's Avatar
tincup64
220 - my brother in law is an electrician, so was an easy thing for me.
tin
Old Jan 16, 2013 | 09:14 AM
KCFLHRC's Avatar
KCFLHRC
tin
Do you remember if it was direct wired or required some kind of receptacle? Reason I ask is electrical wire and hardware can get very pricey.
Thanks for the info.
