2011 FLHTCU detachable tour-pak install problem
Old Jan 22, 2013 | 07:36 PM
acchd's Avatar
acchd
Hey benson1603 that is correct.
Originally Posted by benson1603
ok ACCHD i see what you're saying. the front opening of the tour-pak mounting plate slips over the metal bushings (mounted on the inboard side) of the front docking mounts NOT the black plastic bushings. that is correct, right?
Old Jan 23, 2013 | 12:02 PM
Roger Rimshot's Avatar
Roger Rimshot
One warning about these kits......make sure you periodically check the rear T/P latch screws. Mine worked loose and I could've lost the T/P going down the road. Fortunately, I only lost a wave washer somewhere on the driveway.
Old Jan 23, 2013 | 04:12 PM
BlkVlvtRydr's Avatar
BlkVlvtRydr
Here are a couple pics that may help. When I installed this on mine I installed the tour pak mount first then mounted the tour pak on while the mount was still attached.
Hope this helps.
Attached Thumbnails 2011 FLHTCU detachable tour-pak install problem-003sqx.jpg   2011 FLHTCU detachable tour-pak install problem-584168453o.jpg
Old Jan 24, 2013 | 09:38 AM
benson1603's Avatar
benson1603
thanks everybody, yeah i finally removed the plate from the bottom of the t/p and did what you did BLKVLVTRYDR and then i realized how stupid i was. you know how you get something in your head and you can't see the solution for trying. again thanks you guys. it looks good and i can't wait until i can ride it without the tour-pak.
Old Jan 24, 2013 | 09:41 AM
Jswerve's Avatar
Jswerve
Yes that is correct. The front goes over the chrome spacers not the black portion that your backrest mounts to.
anaya3888
Jan 21, 2014 08:14 AM
Golden State
Aug 21, 2011 06:03 AM
klaybus
Jul 22, 2011 01:34 AM
shortride
Mar 12, 2010 06:02 PM
buckwheat
Jan 17, 2009 11:23 PM
