Cat-Less Head Pipes on eBay
Old Jan 22, 2013 | 08:23 AM
dugan's Avatar
dugan
Default Cat-Less Head Pipes on eBay
Has anyone purchased these? I'm wondering if there was any issue with them fitting since it looks like he cuts them in half then removes cat and welds back together....opposed to cutting a window out and removing cat. Any buyers of these I would greatly appreciate feedback.
http://www.ebay.com/itm/HARLEY-TOURI...90523854707%26
Old Jan 22, 2013 | 08:38 AM
Miked053's Avatar
Miked053
ordered the same ones a while back and no problems at all
Old Jan 22, 2013 | 09:05 AM
07FLHT's Avatar
07FLHT
I had the same worry, thats why I purchased from B&E. Costs a little more but was worth it to me. I think he puts some on ebay sometimes (?)
http://www.superflowmufflers.com/products.htm
PS: The one I got must have been a brand new take off, no bluing or discoloration at all!
Old Jan 22, 2013 | 09:55 AM
hardheaded's Avatar
hardheaded
i wouldn't use one that was cut in half the expantion rate may be different and end up with a crack, just my .02 cents.
Old Jan 22, 2013 | 03:25 PM
dugan's Avatar
dugan
Thanks, I will look into those.
Old Jan 22, 2013 | 03:30 PM
KCFLHRC's Avatar
KCFLHRC
It's an easy modification to cut it in half, remove the CAT and have it welded back together. Cost me $35 to have it welded and no issues what so ever. These guys on Ebay and other sites are making a killing doing this and they all do it the same way.
Old Jan 22, 2013 | 03:40 PM
Frankenbagger's Avatar
Frankenbagger
FWIW, it was cut and welded in a fixture, so no mounts or anything moved. And the stock exhaust is welded together at the factory (along with nearly ever other factory/aftermarket exhaust for cars and bikes), and there's not problems with all of those cracking...
While he is making a killing off of these considering the work required, $135 is about the going rate for one that was done right like this. Then you can probably sell yours to someone who removes the cats out of them (guys like this ebay seller have to get them from somewhere right?). Maybe even email him and see if he will work out a "core charge" for your pipe.
Old Jan 22, 2013 | 03:51 PM
mech-a-nic's Avatar
mech-a-nic
got one i did my self to hold me till I bought my true duals 125.00 Ill put them in the mail. I cut a box out the side and rewelded. cut was on the inside cant see with or without the shild Pics if you want.
Old Jan 22, 2013 | 04:02 PM
Jerry L's Avatar
Jerry L
I'm sorry, mech-a-nic, what did you say? I was, uh.......distracted.
Jerry
Old Jan 22, 2013 | 04:23 PM
ShadowMonster's Avatar
ShadowMonster
Damn!!!! the true dual cheapy setup he sells for the 95-06 is identical to the fullsac setup but $40 cheaper $139
