SERT OR PCIII
Old Feb 7, 2007 | 04:31 PM
98rdking's Avatar
98rdking
Default SERT OR PCIII
Is the SERT anymore difficult to install and set up vs the PCIII? Everyone says PCIII is plug and play. Its come down to the wire and I and trying to decide if long term I'd be better with the sert. Thanks,
Old Feb 7, 2007 | 04:54 PM
bountyhunter's Avatar
bountyhunter
Default RE: SERT OR PCIII
An optimized tune with either requires a dyno/experienced operator....therein lies your answer!
Old Feb 7, 2007 | 05:41 PM
Rocket Jockey's Avatar
Rocket Jockey
I would suggest finding your tuner first and asking them what they prefer. There are pros and cons to both. Doug Lofgren whois a well known tuner suggested Igo with the SERT and because he is my tuner of choice, that is what I will do.
My $0.02,
RJ
Old Feb 7, 2007 | 06:03 PM
GOSTAZ's Avatar
GOSTAZ
Agreed... Find the tuner... ask about how he tunes.. Ask what he likes and why. I have a SERT because that is what the person runnning the dyno said he liked. Unfortunately, he was not a tuner. I found a tuner that I think knows what he is doing, but he is PCIII guy... D'oh! As I understand it, SERT actually burns the changes to the ECM. I cannot verify that, need to do some more reading.
My advice is to have a clear idea of what you want. Are you looking for HP, cooler running, more mid-range, whatever.. take what you want to a few dyno places, and ask them how they would do it.. If you get a weird answer, keep walking...
Old Feb 7, 2007 | 06:45 PM
Retired_Ted's Avatar
Retired_Ted
The SERT "marries" itself to the bike's ecu. Once it's installed, it will never work with another ecu. Both devices are fine - their utility completely depends on the tuner, as was said before. We have very little experience with the SERT and the PC III seems to do everything we ask it to do. The SERT does allow the O2 sensors to stay connected even though I haven't a clue as to whether that's good or bad. O2 sensors are supposed to help maintain the correct A/F ratio - but, we have seen that that's not always the case (with the SERT). Again, just make sure your tuner is competant using which ever one he/she suggests (gotta be politcally correct).
Old Feb 7, 2007 | 06:46 PM
alexcue's Avatar
alexcue
as i understand it, GOSTAZ, the SERT doesn't reside in the bike, like the PCIII does. It actually makes changes on the ECM, as u said.
Old Feb 7, 2007 | 06:58 PM
GOSTAZ's Avatar
GOSTAZ
SERT is the most expensive computer cable I own![sm=icon_guiness.gif]And you are right, it does not stay on the bike. I have run into more tuners as of late that seem to have more experience on the PC III. Sorta wish I had gone that route. Oh well.
jsimo7
Dec 20, 2007 06:28 PM
CLL375
Apr 16, 2007 09:37 PM
hd_sob
Mar 13, 2007 02:40 AM
mkultra
Southwest
Feb 26, 2007 01:34 PM
E.V.
Aug 16, 2006 10:39 PM
