Drive Belt Squeak/Noise, Fact Or Fiction?
Old Jan 27, 2013 | 01:45 PM
rpking's Avatar
rpking
My 2013 Street Glide had a rubbing noise from the drive belt.
When I had my 1000 mile service done the tech loosened it. The noise was gone and hasn't returned.
Old Jan 27, 2013 | 02:20 PM
Jinks's Avatar
Jinks
Check your belt tension. When it's correct ride the bike around the block. When you pull back into the drive stop the bike & DON'T LET IT ROLL BACKWARDS! Look at the belt on the rear pulley. There should be a small space between the belt & the pulley edge on each side (they don't have to be equal). If there's space & your tension is correct, you're set. If there is no space on one side your wheel is out of alignment. If you allow the bike to roll backwards this won't work.
If tension & alignment are correct just run it till the noise goes away or let the warranty fix it if you have a problem.
Old Jan 27, 2013 | 03:07 PM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Originally Posted by Lowcountry Joe
I don't think anyone is going to change a touring belt along side the motorway. That's a major operation.
I was referring to an equivalence of this kit:
Harley-Davidson Emergency Drive Belt Replacement Kits #40109-86
Old Jun 10, 2013 | 12:06 PM
Dispatch's Avatar
Dispatch
Well.... 2,000 miles later and its still squeaking!
WTF??!!
Old Jun 10, 2013 | 03:06 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
WTF??!!
Did you try dusting it lightly with talcum (baby power) and see if the noise will go away for a short while?
Old Jun 11, 2013 | 12:16 PM
Dispatch's Avatar
Dispatch
I tried all that was suggested with no success.
Old Jun 11, 2013 | 12:27 PM
Def Mute's Avatar
Def Mute
Go to automotive parts store...
Get some belt dressing. Comes in a spray can. Spray the belt. Do this each time it wears off...
Old Jun 11, 2013 | 01:18 PM
Jackie Paper
If the talcum did not make it quite for a least a day or so, it's something else. Only reason I said to use it is it will quieten a belt and then you are sure that is what it is. It's like putting a little grease on it, but it soon goes away (unlike grease) You have the rubber drive blocks in the rear pulley. Could it be that? You should not need anything on the belt drive, and I would put nothing on it. If it truly is the belt, your rear wheel must be severely out of alignment with the motor making it rub hard on one side of the pulley and have the belt cogs not perpendicular to the drive pulley .
Old Jun 11, 2013 | 01:43 PM
treefiddy's Avatar
treefiddy
Did you try to clean and lube the rubber mounts for the mufflers under the bags? These are known to get a bit dirty and squeak as well.
Old Jun 11, 2013 | 02:30 PM
Retrop's Avatar
Retrop
Is this squeeking noise really, really loud?
Do you think that the belt is going to break because of it?
