Lighter Touring Wheels
If anyone is really determined to shed weight, HDF sponsor Howard at Motorcycle Metal can supply carbon-fibre wheels......
In any case, losing unsprung weight is never a bad thing for handling, braking and performance.....
So, I bought Hogpro 6-Packs in 16x5 and 18x3.5. Darn nice looking wheels BUT heavier than the OEM. Here's a crummy shot of the front.
The rotors are EBC. Weight comparison follows.OEM w/ stock, moderately worn Dunlops, rotors, no rear pully weigh:
Front -- 40.8 lb; rear 48.2 lb
Hogpro 6-Pack w/ rubber (new front) EBC rotors, no pulley weigh:
Front -- 41.8 lb; rear 53.6 lb ...
I do not have separate rotor weights, but the EBC's are lighter, maybe more than lb each... In the end, I spent a pile on beautiful 6-Packs (made in USA) that are heavier.
Also, re the pulley. As I have a 2-1 ProPipe the pulley is very visible so the stock had to go. I ended up going with ***** Shiny. Nice. This is odd: my stock pully (w/ bumper) weighed 6.6 lb while the two versions of plated OEM I got from WS (w/ bumper) weighed 6.4 lb. (One WS pulley had a flaw. He exchanged no problem.) I do not get this. I figured the chrome would push the weight up. Yes, the HD model numbers were idenitcal.
Have not ridden the new wheels yet. Finished install last weekend. I'm a bit spooked as this is my first time removing/installing any rear and installing aftermarket wheels on an 800 pound bike that I ride on the Washington DC beltway at 80 .... I hope I did not screw anything up and the HogPro spacing and bearings are good. (After I installed chrome lowers last year I had visions of the forks falling off.)
So, good luck.
Jef
____________
Ride Wright wheels http://www.ridewrightwheels.com/ has provided me info, as follows:
16 x 5.5 60 spoke (smooth) 24lbs
18 x 3.5 60 spoke 25lbs
(These are steel hoops and stainless spokes. RW also makes aluminum hoops but not in 16 x 5.5.)
Evolution mags
18 x 3.5 24lbs
16 x 5.5 26lbs
Windmill (no rivets) mags
18 x 3.5 25lbs
16 x 5.5 27lbs
