Tire mileage?
Old Jan 29, 2013 | 05:47 AM
KeeBee's Avatar
KeeBee
Default Tire mileage?
Tried searching and couldn't find an answer. Got 8000 miles on my 2012 Street Glide and it looks like I can get another 3000 or so miles out of my tires. Plenty of tread left on both the front and rear tires. I don't do burnouts or ride like I have a sport bike / VRod.
Question is how many miles are you getting out of your front and rear tires?
Thx for any help.
Old Jan 29, 2013 | 06:11 AM
hammr_hed's Avatar
hammr_hed
all tire's are different. Riding style and most definitely location play big roles as well as continuous 'correct' air pressure. Down here in South Flordida, the heat eats up most any tire in much less time than other areas of the country barring other southern states with temps/humidity that are staggering.
that being said, I got 16.5k on my Metz front...but it was cupped big time and rode like crap. I didn't realize how bad it was until I got it back Saturday. The rear I only got 5k. I could have left it on another few K but I just had a 107" big bore kit installed and didn't want a flat tread line for the new motor. I kept it as a spare.
Sorry for rambling...I'm a morning person
Old Jan 29, 2013 | 06:16 AM
VTL nut's Avatar
VTL nut
The newer bikes (09 and up) are getting about double out of the oem Dunlops.
Instead of the usual 5-6K we used to get, a few peeps I ride with are getting 12K or so.
riteway's Avatar
riteway
15k on my last stock rear before changing...Should get 30+ plus on my stock front..04 FLHT.
Old Jan 29, 2013 | 06:25 AM
Odhar's Avatar
Odhar
You also have to consider the tire hardness. The higher the speed rating the lower the wear factor. High speed tires are usually softer to handle cornering and grip the road and touring tires are usually harder.
Also the tire your bike is recommended for is based on the weight of the bike at production time. Does not consider you adding bags, flaring, and all that other touring stuff to them.
When you buy a tire, their is usually a wear factor, Car tires are numbers the cheap $35 dollar tires are usually around 250 my Firestone SS have a 500.
The more expensive the tire the higher the wear factor. Sportsters call for a Speed rating of H. But I can go up or down one letter and be ok. The Letter system is for Speed. Usually for FAST you can actually go up to a Z.
Next time I get tires I will ask about the wear rating. The Ratings are Wear, speed, Braking (which is usually wet condition) and I think there is 1 or 2 more that I can not think of. Have not read it in a few years.
Like Hammr said, tire pressure is a big part of it.
Mine are 1 year old and got just about 6K miles on them.
Old Jan 29, 2013 | 06:52 AM
jeffreydsilver's Avatar
jeffreydsilver
09 Road King here. 12,500 on the originals and still going strong!
Old Jan 29, 2013 | 07:00 AM
03dragonRK's Avatar
03dragonRK
This is very true. I noticed that when I ride in the southern states that my tires do not last as long. The road surface looks more abrasive then it does in the north.
I was able to get around 21,000 miles out of my stock tires and I had not hit the wear bars yet. The front had more tread, but was cupped so bad I was happy to replace it.
Old Jan 29, 2013 | 07:03 AM
Joe12RK's Avatar
Joe12RK
over 12,000 miles on mine too, and looks like another season left in the rear, will probably replace both with WWW when it's time. I can't complain about the stock tires life, can I? I wonder how other brands compare on the same bike? Joe
Old Jan 29, 2013 | 07:36 AM
BigDawgQC's Avatar
BigDawgQC
I got 14k on the front before replacing (replaced early due to infamous "cupping") & 18k on the rear before replacing.
Old Jan 29, 2013 | 07:48 AM
keith t's Avatar
keith t
Dunlop E 3s front and rear, sitting now at 14K with probalby a few thousand left, pretty calm riding....mostly commuter to work on the hiway
