Cruise Control
Old Feb 8, 2007 | 10:44 AM
mmartin's Avatar
mmartin
Default Cruise Control
I finally got to start my new Street Glide yesterday YEE FRIGGIN HAA. It took three weeks for the dealer to recieve the V/H's pipes and fuel pack.
I have not taken delivery on the bike yet, so I was thinking about having cruise control installed while waiting for the weather to break.
CC not high on my list because I don't like riding the interstate. Should go for it?
Oh yeah, what about that special pump HD makes for the shocks, do I need that? Im a old MX'er and like my shocks set up correct, im still having trouble with the idea of two inchs of travel though.
Old Feb 8, 2007 | 11:54 AM
em2780's Avatar
em2780
Default RE: Cruise Control
MMartin
Just had cruise control added to my 2006 RoadKing wish I had it from day one. If you have the $$$$ go for it. In terms of the pumpHD for the shocks it is a low cost item to keep the shocks at proper pressure. I would not use anything other then a hand pump designed for the shocks.
Old Feb 8, 2007 | 12:00 PM
EasternSP's Avatar
EasternSP
If you're not going to be doing much Interstate riding, the CC won't be of much value. Same as in a car, if you're doin a lot of winding roads and traffic, ya want to have control of the gas.
As far as the shock pump, I thought I would be doing a lot of adjusting, but after a few times, I really don't see that much of a difference when I'm ridin one up.
Old Feb 8, 2007 | 12:07 PM
BladeMan's Avatar
BladeMan
I would get the cruise. Sometimes when your right hand needs a rest its pretty handy. I sometimes just hit the back roads, set the cruise on 30 or 40, and putt arround. You will need a good low pressure pump for the shocks.
Old Feb 8, 2007 | 12:20 PM
StreetGlider56's Avatar
StreetGlider56
The times you need to rest the right hand.. you'll wish it was there...
Go for it...
I'm adding it to my SG this spring...
Old Feb 8, 2007 | 12:29 PM
iclick's Avatar
iclick
ORIGINAL: mmartin
Go for the cruise. It's perhaps the best accessory HD makes for touring bikes, IMO, or very close. I use it on rides on the backroads as well as interstate, and it's so versatile you can use it in group rides even when the leader is constantly varying his speed. OTOH if he's too irratic you'll just need to give up. While activated, just a flick the switch toward Resume bumps it up 1mph, toward Set it goes down 1mph. Hold either and it accelerates or decelerates, very similar to car cruise controls.
You'll need a hand pump for your shocks unless you keep them at zero all the time, not likely when you pack for a trip or ride two-up. If you use a motorized air compressor you'll need to keep it regulated, because you could blow out the shocks or lines if over-inflated. I think the pump should be standard in the tool kit for a bike costing $20k. The SG has less travel than regular touring bikes, and at 165 lbs. I've had mine set to 5 lbs., but yesterday I knocked it down to zero for a trial today. It was a bit firm in the butt before, so we'll see if this helps. The spec for my weight is 0-10 lbs.
Old Feb 8, 2007 | 12:40 PM
Abnmarine's Avatar
Abnmarine
Cruise is a nice option to have. I say get it.
Old Feb 8, 2007 | 12:45 PM
choochoo's Avatar
choochoo
Ever since cruise became available I put it on.
Really is convienent on long rides.
However, most HD's come with a throttleset screw mounted under the throttle grip.
Have used that to maintain speed long enough to rest hand. Just don't tighten it
too tight.
J&P cycles shows a thumb adapter for it to make it easier to set and release while riding.
Just remember it is set and throttle will be stiff if you need to suddenly reduce speed.
doing this is NOT considered safe.
Many after market companies also offer a friction throttle clamp you can mount to the
throttle grip too.
just an idea.
Old Feb 8, 2007 | 01:34 PM
t_m34's Avatar
t_m34
Cruisecontrol isn't just for the slab for sure.There's a stretch of road on my way to work that has hills and is pretty much a steady speed for 10 minutes. I get to 4th gear, set the CC at the speed limit and sit back and spend the next 10 minutes relaxing. It adjusts really well on hills as far as I've seen (of course, I ride in the south mainly) and allows you to keep your bike at a steady speed so you can concentrate on other things other than your speedo.
Mine responds instantly to brake input in a much better way than a throttle lock/tension could ever. On top of that when I do need to brake my hand isn't all crampy and exhausted...I noticed a much faster, more modulated reaction to braking situations after riding for long stretches.
Plus if you ever do get on the super slab and kick it up to speed it's nice to set it and relax your hand.
If you can get it put in I would. You won't regret it.
Old Feb 8, 2007 | 01:56 PM
Edmo's Avatar
Edmo
Another thumbs up on the cruise control... I thought I would never use it on my Road King Classic, but I was wrong! I use it on the big roads and even on two lane backroads. It maintains speed even when running up and down hills two-up.
For the shocks and air pressure, I rarelycheck it. If I plan to haul aloadI'llcheck it, but that's a rare event. Since my wife now rides her own bike, two-up rarely happens.
I've found mynail gun compressor works fine to top it off. When I dial down the regulator to almost nothing,I don't run a risk of over pressurizing the system likewith my big compressor. My low pressure 4-wheeler air gauge (1-20 PSI) does a great job of checking the pressure once I'm done.
Edmo
